Fuel pump help needed asap.
Old May 17, 2009 | 08:28 PM
shank0668's Avatar
shank0668
Default Fuel pump help needed asap.
I bought a fuel pump for a 78 corvette and it only has a in fuel hole and an out one, should it also have a hole for a vent line?
Old May 17, 2009 | 08:47 PM
shank0668's Avatar
shank0668
ttt
Old May 17, 2009 | 09:14 PM
TimAT's Avatar
TimAT
Is there a return line on your frame next to the feed line? The feed line is 3/8 and the return line is 1/4. If your car has both lines on the frame you have a choice. Either back to the auto parts store and get another pump ( one with a return) or plug the return line on your frame.
GM put the return line on to help with hot fuel issues. vapor lock
Old May 17, 2009 | 09:27 PM
shank0668's Avatar
shank0668
Whats the downside of plugging it?
Old May 17, 2009 | 09:41 PM
69elky's Avatar
69elky
Default pump
Get the correct p/n pump for your application,
Old May 17, 2009 | 09:54 PM
shank0668's Avatar
shank0668
where I got the pump is an hour or a little less away............
Old May 17, 2009 | 10:12 PM
mikep3's Avatar
mikep3
Default Fuel Pump
Autozone, Advanced Auto, PEP Boys, NAPA or any of our supporting vendors.
The correct pump is about $35.00. Two tubes, on supply, one return and a threaded port for tubing fittings to the Carb.
Old May 18, 2009 | 09:10 AM
Mike Ward's Avatar
Mike Ward
We get to call you Bubba and you possibly get to deal with vapour lock or flooding carb. Send it back and get the correct three port pump.
Old May 18, 2009 | 04:06 PM
shank0668's Avatar
shank0668
Alright, I have an autozone one on now and it still wouldnt start correctly so I went to local chevy dealer and they said that they had a 70's Camaro and put an autozone pump on and had the same problem, they said get one from them or summit racing.
Old May 20, 2009 | 06:50 PM
shank0668's Avatar
shank0668
ttt
Old May 20, 2009 | 07:22 PM
...Roger...'s Avatar
...Roger...
Thats common with aftermarket pumps. The check valve in the pump doesnt work very well which means the fuel in the carb sipons back to the tank. Buy an AC from the dealer and that should fix it.
I put a cheapy on my car just to see. Lars had said if you remove the clip from the needle it might stop the fuel from draining -- it did.
Old May 21, 2009 | 01:41 PM
Vegas69's Avatar
Vegas69
How much fuel pressure will the stock AC fuel pump provide? I just got my healthy 383 back from the machine shop. I hate seeing the return line sitting there with a plug and I'd like to put it back in the system.
To Fuel pump help needed asap.
