Blown Stroker
Old May 19, 2009 | 01:38 AM
jordan89's Avatar
jordan89
Default Blown Stroker
Hi I'm looking to build a blown 383 Stroker, and the rotating assemble I purchased is part #SCA-1-90355BE
http://store.summitracing.com/partde...E&autoview=sku
I am planning on using Weind 177 Pro Street Supercharger, but have to watch the amount of boost since the crank isn't forged. What do you guys think and any suggestions on a supercharger or parts to use? I couldn't get a rotating assembly with a forged crank due to them being too expensive and also because I am a college student, I have to save my money in order to get it done. The pistons and the rods are forged. Right now I'm just looking to listen for suggestions. With 70cc heads the compression would be 9:2, and I figure maybe with some 75 or 76cc heads I would get a compression ratio of around 8:1. I talked to a person from SCAT and told me that the crank is rated at 600hp @ 7200RPM. What do you guys think?
Old May 19, 2009 | 07:57 AM
one-72's Avatar
one-72
go to this site and check out there prices .
Hope this helps you.
Go for the forged assembly.
cnc motorsports
Old May 19, 2009 | 09:00 AM
jackson's Avatar
jackson
Originally Posted by jordan89
the rotating assemble I purchased is part #SCA-1-90355BE ...I am planning on using Weind 177 Pro Street Supercharger...I couldn't get a rotating assembly with a forged crank due to them being too expensive and also because I am a college student, I have to save my money ...... What do you guys think?
You asked.
Focus on school-future; six months after graduation your tastes or your realities (or both) will differ much from today.
For now, use parts you have on hand & fix only what you must ... build a mild, reliable, normally aspirated 383. 76cc iron heads, -18cc dish & fp1094 gasket makes at least 8.5:1 scr 383.
But, if your present motor is running OK then leave it & return or sell kit. Good luck in your endeavors.
Old May 19, 2009 | 09:41 AM
bashcraft's Avatar
bashcraft
Originally Posted by jackson
You asked.
You're going about this all half a$$ed. You bought a rotating assembly that is of questionable strength in a blower application and I'm guessing that you don't have a lot of experience with artificially aspirated engines. Regardless of what the blower manufacturers say, these things are not a bolt on and drive away item.
Old May 19, 2009 | 12:56 PM
jordan89's Avatar
jordan89
I'm not planning on running lots of boost. The engine in my corvette is in really good conditions, it only has 71,XXX miles on it, the car wasn't driven in bout 15 years. If I don't add a blower, I might just go naturally aspirated and try to make as much power as possible.
Old May 19, 2009 | 01:30 PM
gkull's Avatar
gkull
You don't want external balanced.
Old May 19, 2009 | 05:15 PM
jordan89's Avatar
jordan89
Why is that?
Old May 19, 2009 | 06:27 PM
Billysvette's Avatar
Billysvette
Also ,its alright to run cast crank because the 144 and 177 blowers are not suppose to go over 6000 to 6500 rpms.I run a cast crank 383 stroker ,blown.
Old May 19, 2009 | 07:13 PM
gkull's Avatar
gkull
Why is that?
Because it is the poor way to balance a motor. Then in future when you change the damper/flywheel/or flex plate they are not a balanced set with the motor. You really get what you pay for.
Old May 19, 2009 | 07:18 PM
Brass Pass's Avatar
Brass Pass
Removed by edit.
Old May 19, 2009 | 11:15 PM
jordan89's Avatar
jordan89
I really want to have a blown stroker, I did a lot of research and contacted someone over at SCAT to give me a little bit of more info on the rotating assembly and the told me that the rods can handle up to 750hp and the crank 600hp@7200RPM, which is good enough. Do you have a blown 383 or a 350? How much power is it putting out? If I do the blown stroker I'm not going to drive it every day, only in the weekends, I have a 78 Z28 Camaro that's the daily driver for going to school.
To Blown Stroker
