Transmission fluid
Old May 19, 2009 | 07:49 PM
BassCat's Avatar
BassCat
Default Transmission fluid
Just wondered what transmission fluid others were running in their automatic C3s. Dextron III/IV/V? Synthetic or no? Mine's a '77.
KC
Old May 19, 2009 | 10:17 PM
marshrat99's Avatar
marshrat99
I put in a new BTO 2004R and they recommended using the cheapest Dextron (II or III??) on sale but change the fluid and filter at the recommended mileage and at a minumum once each year. Given the investment I've made with my BTO level 3, I'm going with BTO's suggestion.
Old May 19, 2009 | 10:29 PM
Glassbowtie77's Avatar
Glassbowtie77
I changed the filter in my TH350 and have been running Valvoline Maxlife Dex/Merc in mine without a problem.
Old May 19, 2009 | 10:33 PM
TimAT's Avatar
TimAT
All I can add is please don't use any Type F fluid in a GM trans that you want to last. The type F fluid does not have the lube qualities that Dexron has. It's hard on GM's bearing, bushings, and clutches.
And before someone jumps my case with "I"ve been using Type F for years with no problems", I've had several GM trannys apart that were run with Type F- the bearings were not useable, and the clutch plates were coming apart.
offroadtoyota's Avatar
offroadtoyota
My rebuilder told me if GM put Dextron in about a gazillion vehicles, it would be fine for my application. Why spend the extra money if you don't have to?
Old May 19, 2009 | 10:35 PM
Ironcross's Avatar
Ironcross
Type F is the best for performance to the exclusion of all others no matter what the brand or style of automatic transmission
Old May 19, 2009 | 11:34 PM
gingerbreadman1977's Avatar
gingerbreadman1977
dexronIII all the way. its all i have ever used . . its what the manual recommends so thats what it gets.
To Transmission fluid
