Speedo cable leak on Tremec
Old May 21, 2009 | 01:04 AM
blueray72's Avatar
blueray72
Default Speedo cable leak on Tremec
I cannot get the o ring to seal on my Tremec TKO. Has anyone experienced this? Does anyone know what size o ring is used?
Old May 21, 2009 | 09:55 AM
blueray72's Avatar
blueray72
ttt
Old May 21, 2009 | 10:29 AM
midyearvette's Avatar
midyearvette
yes i have that trouble and not only does the o ring leak but the cable housing itself at the tranny....will try to fix it this winter with a new custom made cable, housing, and i dont know what for the o ring....time to cruise this summer......
Old May 21, 2009 | 10:46 AM
blueray72's Avatar
blueray72
I'm not positive that the o ring is the only leak. There might be a leak at the housing where it crimps onto the cable...
Old May 21, 2009 | 10:59 AM
Gordonm's Avatar
Gordonm
I still get a drip out of mine. I have replaced the cable once with an updated version??? and I still get a drip. It drips right on my exhaust pipe so I have a nice brown stain on it.
Old May 21, 2009 | 11:09 AM
Brandywine's Avatar
Brandywine
I am by no means an expert on this subject, but I just experienced a similar problem. My speedo was jumping around and then quit. The culprit in my case was a bad cable. The windings around the center cable were installed backwards (i.e. the whole cable was backwards in the housing) causing the cable to suck up fluid into the housing. It eventually would have leaked out the top at the speedo, which had a bad crimp... After playing with a replacement that had the same crimping problem the speedo and leak are fixed...for now.
Old May 21, 2009 | 11:16 AM
blueray72's Avatar
blueray72
yep..right on the exhaust. And that fluid aint cheap
Old May 21, 2009 | 11:24 AM
midyearvette
maybe your yoke is leaking too...mine did and they sent a replacement...just a thought......
Old May 21, 2009 | 11:28 AM
blueray72's Avatar
blueray72
My yoke leaked a little but has seemed to stop
I've been checking everything to try and find where the leak was coming from.
Old May 21, 2009 | 11:37 AM
midyearvette
that pesky leak was because the yokes were junk and the welch plug leaked at the rear...they sent me a "new and improved" one that actually had some rtv smeared on the outside!!.....needless to say i knocked out the plug and put in a new one with some jb weld and all is good as far as that leak...to test it pull the yoke and set it upright on a work bench and fill it with lacquer thinner.....give it a minute or so and see if a few drops fall on the bench...good luck.....
Old May 21, 2009 | 03:14 PM
WESCH's Avatar
WESCH
Hi
Had a leak from the speedo cable connection to the T56 mechanical speedo drive adapter.
Oil puddle on the garage floor.
I installed a flat rubber Ring ( like used for water faucet tubes ) and the leak is gone. There is nothing holding the fluid back once the car stops, so it runs back into the cable and out of the thump screw if not sealed.
Pretty stupid design.
Rgds. Günther
Old Jun 2, 2009 | 10:23 PM
blueray72's Avatar
blueray72
found location of leak...or at least hopefully the only leak. It's leaking at the cable wear the housing is crimped. does anyone have any suggestions?
Gordonm where did you get your replacement?
Old Jun 2, 2009 | 11:33 PM
gve's Avatar
gve
My tremec leaked at the crimp when I put it in 3 years ago I cleaned it good and put some gray silicone where it crimps it hasn't leaked since.
Old Jun 3, 2009 | 12:16 AM
Silver 7T8's Avatar
Silver 7T8
A suggestion that I might offer is the following supplier -->
Speedometer Service Co. 5801 W. Villard Ave. Milwaukee, WI 53218
Attn: Roger Luckow (www.speedometersolutions.com)
I had a custom cable built for a TKO 5-speed conversion from a 1978 Turbo-350 with cruise control - I kept the OEM cruise control system intact- thus needed the "TKO" speedo-cable (Ford) on one end & a screw-type cable end for the GM cruise control on the other end.
Roger built the cable & offered a choice of a plastic-jacket OEM type cable or an upgrade steel-jacket cable that would be more durable especially when exposed to exhaust-pipe heat. No leaking & smooth speedometer needle action.
I chose the upgrade cable he included the needed speedometer cable plastic gear calculated from my tire diameter & rear-end gearing - I also supplied him with the needed length.
Total cable & gear cost was $92 including shipping. Hope this helps.
Old Jun 23, 2009 | 05:35 PM
blueray72's Avatar
blueray72
thanks for the link...gonna try and seal the crimp area to confirm that's the only leak I got.
Old Jun 23, 2009 | 05:45 PM
Gordonm's Avatar
Gordonm
My cable came from Keisler.
Let us know how that fix works. I'll give anything a try now. My exhaust pipe is quite brown in that area. My yoke does not leak. That was one of the first checks I did
To Speedo cable leak on Tremec
