1977 Corvette Key Question
Old May 24, 2009 | 10:47 PM
xkeots's Avatar
xkeots
Default 1977 Corvette Key Question
Help,
Does the back compartment, the doors and the alarm all have the same key?
The person who I got the car from lost the keys and changed only the passengers door & the ignition keys.
I was wondering that if I had a locksmith copy the back compartment lock & make a key, would it open the passenger door & work the alarm?
Jack
Old May 25, 2009 | 03:43 AM
seanymph's Avatar
seanymph
1st Gear
Hi, The door key and the back compartment key are the same on my 77
chris
Old May 25, 2009 | 07:33 AM
Ganey's Avatar
Ganey
Yes, that should do it.
Old May 25, 2009 | 02:40 PM
xkeots's Avatar
xkeots
chris
Thanks but then which key was for the alarm in the fender?
Jack
Old May 25, 2009 | 05:14 PM
Binnie77's Avatar
Binnie77
Jack
Alarm key is the same lock as door and rear compartment. The square key is ignition only.
Old Jun 9, 2009 | 10:21 PM
xkeots's Avatar
xkeots
Thanks All,
I was able to have the key made for the rear glove box and they cut in one more tooth after a few tries and the key now works in my alarm, rear box door & passengers door. The last owner must have lost the keys and used non original tumblers for the column & the drivers door so I have an extra key for the drivers door. This key is the wrong blank for the tumbler that they put in my drivers door. No problem.
Jack
Old Jun 10, 2009 | 08:35 AM
71rdster's Avatar
71rdster
Don't forget the spare tire lock.
Old Jun 10, 2009 | 11:53 AM
xkeots's Avatar
xkeots
There is none
Jack
To 1977 Corvette Key Question
