Differential gear swap
Old May 25, 2009 | 08:00 PM
thiatt's Avatar
thiatt
Default Differential gear swap
I'm going to change the ratio on my '77, from 3.08 to 3.70. Will I need a new "posi" pack or are these the same? Also if they are the same, can they be rebuilt for cheaper than new? Any other advice or know how is much welcome. Thanks
Old May 25, 2009 | 08:08 PM
bernie payne's Avatar
bernie payne
I am getting ready to do the exact same thing on my 76, and I am not that sure either.
Old May 25, 2009 | 08:35 PM
Grumpy 427's Avatar
Grumpy 427
No you should be fine. Its when you go to a 4 series gear that you need a to go to another posi carrier. I think its Richmond that makes a 3.73 gear to fit where a 4.10 gear used to be. So thats the only one i know of that is swapable in that regard.
Old May 25, 2009 | 08:38 PM
Gordonm's Avatar
Gordonm
All the 3 series gears will fit a 3 series carrier. There are some gear manufacters that make 4 series gears fit a 3 series carrier. You cannot make a 4 series gear fit a 3 series carrier.
Yes you can replace the clutch packs, beware of the cheap ones, they are not good and will self destruct. If you need info on the rebuilding contact Gary gtr1999 here on the forum. He is the expert. I have done a few myself but he has done many.
Old May 25, 2009 | 08:42 PM
thiatt's Avatar
thiatt
Thanks. Are these clutch packs common or special order thing, been looking for them but only able to find the whole assembly.
Old May 25, 2009 | 08:50 PM
Gordonm's Avatar
Gordonm
Pretty common. Most vendors carry them.
http://www.zip-corvette.com/Zip/dept...2741418AFF99D2
Old May 25, 2009 | 10:22 PM
thiatt's Avatar
thiatt
Thanks again, much more budget friendly.
Old May 25, 2009 | 10:25 PM
Artsvette73's Avatar
Artsvette73
The clutch pack is still available from GM
To Differential gear swap
