1980 Wiper delay
Old May 26, 2009 | 03:31 AM
80 L48's Avatar
80 L48
Default 1980 Wiper delay
I need to know where to find a wiper motor cover in good condition. All I can find is a plain cover without the wire. My delay doesn't work because the contact is bad I think. It is old and worn pretty bad. Can't seem to find that part. Thank you.
Old May 26, 2009 | 06:56 PM
Sean82's Avatar
Sean82
I will suggest that you check your motor.
The pin that rotates around makes contact with the delay wire on the wiper cover. The bushing around the pin get worn and the pin gets sloppy and misses the cover.
you can fix the pin with a 1/4" bolt and a drill press
Old May 26, 2009 | 07:04 PM
69elky's Avatar
69elky
Default cover
I believe this is a discontinued item at the moment,I have one for my seventy nine as a back up.It looks like Paragon has a cover new listed for $19.00+ shipping,not sure if it is for intermittent wipers,has photo.Paragon part #12458,1-800-882-4688,corvette-paragon.com
Old May 26, 2009 | 08:08 PM
Duke94's Avatar
Duke94
There was a guy selling them on eBay all the time. Try a search.
Gary
Just did a search, turns out the 'guy' was Corvette Central. but I think this is one you already found.
http://cgi.ebay.com/ebaymotors/1975-...61210007r27751
Old May 27, 2009 | 01:49 AM
dalewilson99's Avatar
dalewilson99
If the contact is still in one piece you could build up the end of it where it touches the wiper motor shaft. Take a narrow piece of tin and form it around the contact end. Make it long enough to stuff under the plastic retainer and solder it to the contact center section.
Dale
Old May 28, 2009 | 02:48 PM
Sean82's Avatar
Sean82
Dale
Dale's right.
I also sanded the black plastic back a bit to ensure metal to metal contact.
Old May 31, 2009 | 01:21 AM
80 L48's Avatar
80 L48
I soldered a piece of tin to where the metal tip was worn off. Not sure if the pin on motor is making contact. No luck yet, but will keep trying. It would be nice to see a photo of the inside of a cover in good condition to compare it to. Do you know a way to test the cover to see if current is going threw it? There looks to be a resistor connected to the wire coming threw the cover. I do appreciate all the advice people have given me on this. Thank you.
To 1980 Wiper delay
