78 Center Console Wiring Help
Old May 26, 2009 | 12:29 PM
PSU88's Avatar
PSU88
Default 78 Center Console Wiring Help
I'm replacing the center gauge cluster console, and came across a wire that "Bubba" capped off, and I'm having a hard time identifying it. It's an orange wire that splits via a blue connector, located just behind center console - pic attached below.
Any help identifying the purpose of this wire would be greatly appreciated!
http://s238.photobucket.com/albums/f...terconsole.jpg
Old May 26, 2009 | 01:00 PM
KapsSA's Avatar
KapsSA
Active Streak: 90 Days
Orange wire in that vicinity is most likely the constant hot lead to a FACTORY power antenna and would terminate at the relay under the parking brake cover all the way to the rear.
That blue connector is not factory. Probably someone's attemp to tap into a hot lead to power something else. Radio memory perhaps?
Old May 26, 2009 | 03:27 PM
doug.storch's Avatar
doug.storch
Default Me Too
I am putting my dash back together in my '78 and I was wondering what the heck that blue "connector" thing is as well
Old May 26, 2009 | 08:16 PM
Duke94's Avatar
Duke94
Orange wire is for the power ant. Here is a link to all the 78' wiring diagrams
Gary
http://www.corvetteforum.net/c3/tune...l/index6.shtml
Old May 26, 2009 | 10:07 PM
PSU88's Avatar
PSU88
Thanks KapsSA and Gary - that's a great site! Mystery solved...
Doug - if you find out where your Heater/AC light wiring is, drop me a note. My old center gauge console has the light guide attached, but no socket, bulb or the black and gray wires anywhere to be found.... If you know where those wires come from, please let me know.
Bill
Old May 27, 2009 | 12:13 AM
Willcox Corvette's Avatar
0Willcox Corvette
Former Vendor
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
Bill
The center bezel housed the heater control lamp on 78-82 cars.
It consisted of the following:
Lens http://willcoxcorvette.com/product_i...ducts_id=17055
Housing http://willcoxcorvette.com/product_i...ducts_id=17056
Bulb http://willcoxcorvette.com/product_i...ducts_id=26366
Bulb Holder http://willcoxcorvette.com/product_i...ducts_id=25916
And a jumper harness that plugged in to the main wire harness. This is what makes the lamp work:
http://willcoxcorvette.com/product_i...oducts_id=4379
Hope this helps you.
Willcox Inc.
Old May 27, 2009 | 12:15 AM
0Willcox Corvette
Former Vendor
I can't get the jumper pic to show? But you can click on the link to see it.
W
Old May 27, 2009 | 10:42 PM
PSU88's Avatar
PSU88
W
Link worked fine! I am definately missing the harness, order placed.
Thanks for the information...I'll be able to see the Heater/AC controls in the dark now
Old May 28, 2009 | 12:01 AM
...Roger...'s Avatar
...Roger...
I dont think thats the right bulb.
Old May 28, 2009 | 12:08 AM
0Willcox Corvette
Former Vendor
Yup! The bulb is pushed in the connector shown above just like a dash bulb on a 1978-1982 but had the special tip. I'm sorry, I did post the wrong picture and link.
Willcox
Old May 28, 2009 | 12:25 AM
...Roger...
I think it should take the that fisheye type bulb.
edit- I'll go out in the shop and check but I think it has a GM part number only.
edit#2 - the number I have is GM #9433183 or Delco #L558
Old May 29, 2009 | 09:15 AM
PSU88's Avatar
PSU88
I believe it's the bulb that has the "magnification" on the tip. I've read that the standard 194 bulb won't work very well to illuminate the HVAC controls.
Old May 29, 2009 | 10:11 AM
Duke94's Avatar
Duke94
Gotta be the fisheye type.
Gary
Old May 29, 2009 | 11:41 AM
JEISNER's Avatar
JEISNER
I put a type 194 in that spot a few weeks ago, it isn't bright enough by far.
Old May 29, 2009 | 04:17 PM
2box's Avatar
2box
Use the one with the magnifing tip......
Old Jun 1, 2009 | 11:38 AM
PSU88's Avatar
PSU88
Does anyone know where the Heater/AC light harness plugs into the main wire harness? Unfortunately, these components were removed in the past, and I can't find the location to plug the light harness into. Any help is appreciated.
I did find the thread below that shows a great picture of the light and how it attaches to the center upper console, but am trying to locate the terminating end location.
http://forums.corvetteforum.com/c3-t...ole-light.html
Bill
Old Jun 1, 2009 | 01:29 PM
Duke94's Avatar
Duke94
This web site will help you.
Gary
Old Jun 1, 2009 | 09:13 PM
PSU88's Avatar
PSU88
Originally Posted by Duke94
Thanks Gary - I missed "Figure A" in the instrument link...I see it now. Appreciate the info!
Bill
To 78 Center Console Wiring Help
