transmission mount install ?
Old May 27, 2009 | 09:35 AM
1nicecorvette's Avatar
1nicecorvette
Default transmission mount install ?
im sorry for a repeat post if this is but, ive searched for an install tip or idea how to do this effectively. And came up with just jacking the trans under the pan with a board.
from what i see under the car.
1.jackstand the front of the car
2.lightly hold the trans under pan (with jack and large flat board) remove the two lower mount bolts,
3.jack it up a bit and remove the two upper bolts?
4.reinstall mount.
am i close? did i miss anything?
Old May 27, 2009 | 09:09 PM
Bob Walker's Avatar
Bob Walker
You've nailed it 1nicecorvette
