wiring harness
Old May 27, 2009 | 11:18 PM
63vert's Avatar
63vert
Default wiring harness
Its time to do the wiring harness. I've decided to stop spending endless hours trying to repair the hacked up mess I inherited.I need some feed back from you guys on who has the best harnesses. The plan is to replace the dash, engine and forward lamp harness to start. Who has used what and why is it better than the other guys.
Old May 28, 2009 | 12:54 AM
Peterbuilt's Avatar
Peterbuilt
www.classiccarelectrical.com
Old May 28, 2009 | 12:58 AM
flyingman21's Avatar
flyingman21
Wilcox will have the best price for a Lectric Limited harness with their forum discount. I got all 3 through them. Super satisfied.
Old May 28, 2009 | 03:17 AM
NotSpdn's Avatar
NotSpdn
take pictures of the old wire harness especially dash wire harness.
I had a hack of a time getting the dash to fit back into place after I installed the new harness.
Do not throw the old harness away until EVERYTHING is back togather. I referred back to the memory of the old harness many times.
I even labeled some of the engine compartment leads before installation. some cars used some leads other do not. such as A/C vsnon-A/C cars
Old May 28, 2009 | 08:36 AM
71406's Avatar
71406
Old May 28, 2009 | 10:00 AM
Duke94's Avatar
Duke94
Letric Limited. Fit was perfect. Use tape to mark what the old connectors came off of so you can get the new one plugged back in the correct place. The hard part is routing the harness over the speedo/tack and down to the center console. Lots of wires in a small space. Take your time and you won't have any problems. It is rather fun to do.
Gary
Old May 28, 2009 | 02:32 PM
73, Dark Blue 454's Avatar
73, Dark Blue 454
Agree,..Lectric Limited. The best there is:
www.lectriclimited.com
Old May 28, 2009 | 03:31 PM
AzMotorhead's Avatar
AzMotorhead
Limping across the line
I use M&H Fabricators for all my harnesses Great Tech support too
www.Wiringharness.com
Old May 29, 2009 | 01:30 AM
63vert's Avatar
63vert
I have to thank everyone for the input and tips. The electrical on this car is scary to say the least, I have a couple wiring diagrams for this car (including the good one from a Forum menber here), there are just too many things that don't add up. I'm affraid if use the exsisting harnesses as a guild I'll be sunk. I need to get the correct plugs and wire ends as close to what they used when assembling at GM. This car was a basket case when I bought a few years ago as project and as many of you know, its becomes an obsession.
I am glad to be a part of this Forum. I've gottem more questions answered and definately saved a lot of time and money over the coarse of this project.
Old May 29, 2009 | 11:10 AM
AzMotorhead
I think Dr Rebuild has a wiring schematic with colors and pictured plug ends to aid in figuring what things are
Old May 29, 2009 | 11:29 AM
...Roger...'s Avatar
...Roger...
Very nice schematic,work of art.
Old May 29, 2009 | 11:47 AM
Jeff_Keryk's Avatar
Jeff_Keryk
Wiring harness replacement is easy. When I did mine, I was kinda scared when I first tried to fire her up. The damn thing started right up and idled like never before. You will be happy...
Old May 29, 2009 | 08:25 PM
Willcox Corvette's Avatar
0Willcox Corvette
Former Vendor
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
I don't have all the 74 harness's moved over to the forum sale side. I'll move the rest of them tomorrow and post a link for you.
Willcox
Old May 29, 2009 | 09:26 PM
barbs '69 resto's Avatar
barbs '69 resto
Account disabled by request 8 Feb 2010
Default harness
I bought my harnesses from Last Detail in atlanta. They had the best prices at the time and they use Letric Limited harnesses.
Old May 30, 2009 | 11:27 AM
0Willcox Corvette
Former Vendor
Below I've pasted the prices for forum members on the 1974 wires. So far I have 1969-1974 and 1979 listed in there. 68, 75-78 will join real soon!
Here is the link:
http://willcoxcorvette.com/advanced_...page=1&sort=4d
VMA7400AC-29241F 1974 Harness. Dash W/Air Conditioning & Seat Belt Interlock 74-74 $419.16
VMA7400NA-29242F 1974 Harness. Dash W/Seat Belt Interlock W/O Air Conditioning 74-74 $419.16
VRH7400-29604F 1974 Harness. Rear All 74-74 $238.58
VHL7400-29345 1974 Harness. Front Lamp 74-74 $198.24
VIG7400MS-29304F 1974 Harness. Engine Small Block Manual 74-74 $167.19
VIG7400AB-29305F 1974 Harness. Engine Big Block Automatic 74-74 $167.18
VIG7400MB-29306F 1974 Harness. Engine Big Block Manual 74-74 $167.16
VIG7400AS-29303F 1974 Harness. Engine Small Block Automatic 74-74 $167.16
VAC7400-29106F 1974 Harness. Air Conditioning W/Heater Wiring 74-74 $137.78
VPW7274-29555F 1972-1974 Harness. Power Window Complete 72-74 $131.88
BC2026-33480F 1972-1974 Battery Cables. Correct W/Grommets 72-74 $95.00
VPL7077-29357F 1970-1977 Front Park Lamp Extensions. 2 Piece Set 77 Early 70-77 $39.75
VAD7375-29450F 1973-1975 Harness. Hood Scoop Cowl Air Door 73-75 $17.50
VML7376-29475F 1973-1976 Harness. Map Light Rearview Mirror 73-76 $17.50
VNS6977-29486F 1969-1977 Neutral Safety Switch Extension. Manual 69-77 $14.95
Old Jun 1, 2009 | 01:12 AM
63vert's Avatar
63vert
Thank you, These prices are the best I've seen. I'll be palcing an order at the end of the week (need to move some money around)
Thank you
Here is the link:
Old Jun 1, 2009 | 11:12 PM
0Willcox Corvette
Former Vendor
Thank you!
I should have the missing links up by weeks end! These are part of the new sale I've been working on. I just turned the harness links on early!
Willcox
Old Jun 1, 2009 | 11:31 PM
Jeff_Keryk's Avatar
Jeff_Keryk
Earlier this year Willcox did me right on the rear lamp harness for my 68. No need to waste time with others...
To wiring harness
