Timing for cam break-in
Tomorrow is the big day, I'll break-in the new cam and we will see how this guy performs.
I've researched a lot around the break-in process and I'm pretty confident it will go fine, now my only lasting question is about the timing I should set during break-in.
Later I will plug the vacuum figure out all the settings and get the curve right, but during break-in I just want to set a good timing for 2000 rpm with the vacuum on and everything.
I don't want to have too much and get to pinging during break-in but also don't want to be too little and see my headers go cherry red. What should be a good number? 40*? 50*? All the way till pinging then a tad back?
And what about the electric choke? Should I let it do its magic or just click it open?
Thanks,
Fábio.
to it. Wouldn't it throw me around 58* way out of the magic 52*? I'm really afraid of messing up my break-in.
Thanks,
Fábio.
I just broke in my XE268H this way and still have not connected the vacuum advance. This weekend I plan to take detailed vac readings, measure for the full curve and dial in the VA. I would not use VA at all for your breakin.
I did by eye looking into pics of the dist before I disassembled the engine.
By the way Jeff was also right about it generating lots of heat. Seems that the electric fan+aluminum rad setup that I have is great to cool down a stationary car during 800rpm idle but dont even get close to be effective cooling a stationary car turning 2500+rpm.
I had to stop the process twice beacause of overheating, the first time was 5 minutes in, but because of the new temp sender that I put in that seems to be the wrong one for the stock vette gauge, after calling Scott for emotional support(thanks Scott) I got it back up took out some advance and used my IR gun to read the temp. It went on for another 10 minutes or so until the temp raised to 220* measured on the upper hose and the 15?psi rad cap started squirting boiling water then I shut it down.
Due to lack of helpers I blocked the throtle open which made shuting off the engine really not funny with scarry sounds and backfires, I do not recomend that, get a helper on the throtle and when you shut it off cut the ignition and the throttle.
All said and done I think it went fine, it fired up right away, no leaks, no pinging, no back fires, no misses, the new headers pipes and exhaust sound really smooth.
Tomorrow I'll change the oil and filter again, retorque intake and exhaust, check spark plugs for mixture, see if the push rods are still spining, check dynamic compression, dial in the timing, idle mixture, idle rpm, and drive it around.
Thanks a lot guys for the support.
Fábio.
I've also set points gap & points timing on the side of the road with only a matchbook flap to set gap ... and a cellophane pak-wrapper betwixt points as substitute for the flickering lamp ... just as cellophane can be pulled from points is about where a lamp'll flicker. I didn't invent that method ... I learned it from a much older gent.
I haven't done a engine break in in 20 years so I'm very rusty. I do have a friends industrial fan lined up for cooling so I'm good there. The cam that HBR Competition Engines here in Vegas put in is a custom grind from Custom Cams Inc and something about the way they are ground allows for a relatively easy break in at 1500 RPM's for 20 minutes. I don't have any junk header so I have to do the deed with my freshly ceramic coated Hooker sidepipes. If I can get it fired, steady 1500 RPM's for 20 minutes and not get the headers too hot I think I'll be good.
Tomorrow we will have a test drive with the tops off
Thanks a lot Scott, Mako, Lars, and all the guys for all the help during this project, this comunity rocks!.
Next stop: rear end...
Fábio.
The surprise is that the old iron heads, stock exhaust, wiped cam, and stock distributor had more humpf on the lower rpms than the new setup
It really wakes up at 4000 rpm where it gets much better, I'll start reading Lars papers on tuning and see if I can get more juice out of this guy at bottom end.
I already got the distrib vacumn advance set to go all out on lower vacumn as this cam generates less vacumn than my stock one, it got slightly better. After that I have replaced the carb's spring for the secondaries with the long yellow one for the same reason but haven't tested it yet. You will definetely see more posts on this
Fábio.
You can static set your inital timing with an old (but working) spark plug.
1) Remove the distributor cap
2) Take the number one plug wire off the number one plug and insert your old spark plug in the boot.
3) Turn the engine by hand to the position that both the harmonic is at 8-10 degrees BTDC and the rotor is pointing toward the number one position if the cap were installed.
4) Loosen the bolt that holds the distributor clamp-down bracket.
5) Turn the ignition key to the "On" position
6) Ground the plug (away from the carb)
7) With your other hand, rotate the distributor back and forth while watching your grounded plug. Stop rotating at the exact position when the plug fires.
8) Turn the ignition key off. (You shouldn't leave the key in the "on" position any longer than necessary if you have either a resistor or resistor wire to your coil. Things can get warm. But this procedure takes less than 30 seconds).
9) Button it up, fire it up.
Good luck!
