Control Arm Shims - Lost!
Old May 29, 2009 | 07:27 AM
belkerx3's Avatar
belkerx3
Default Control Arm Shims - Lost!
Help. I removed my upper control arms last night and I lost the shims that were in the right side. I've searched high and low. They fell out of place and I can't find them.
2 questions:
1 - Where might they have fallen?
2 - Would they be the same thickness as the left side? I still have them.
My car is a 1973.
Thanks in advance for any help.
Old May 29, 2009 | 08:57 AM
a1sensei's Avatar
a1sensei
This may sound stupid, but on my truck, they fall out and lay neatly on top of the upper control arm until I re-install them.
God bless, Sensei
Old May 29, 2009 | 09:11 AM
76stingracer's Avatar
76stingracer
They may not be the same as the other side. Mine have been found in the following locations:
- Between the fan shroud and the cross member.
- Sitting on the cross member at the brake line.
- Under the radiator hose.
- On top of the lower a-arm (as noted above)
- In the spring pocket of the lower a-arm.
- on the ground under the tires.
Old May 29, 2009 | 10:19 AM
MotorHead's Avatar
MotorHead
From: Who says "Nothing is impossible" ? I've been doing nothing for years.
Probably in the same place my 3/8 inch socket fell into 4 years ago
Old May 29, 2009 | 10:21 AM
69vettester's Avatar
69vettester
They fell out and landed neatly on my work bench, I measured them and will be installing next alignment. Thanks alot.
if they fall down on me Ill look for them until I find them
Old May 29, 2009 | 10:29 AM
wcsinx's Avatar
wcsinx
2 questions:
My car is a 1973.
1. Down
2. Not necessarily
They're just for camber, right? That's easy enough to set if you can't find them. Measure the angle of the other wheel (prob. set at 1/2 deg. or so) and match it up.
To Control Arm Shims - Lost!
