still getting an intermittent 'no start'
Old May 31, 2009 | 12:30 PM
Attfay Elleybay's Avatar
Attfay Elleybay
Default still getting an intermittent 'no start'
I'm still getting an intermittent 'no start'. When I turn the key, everything seems normal. The radio comes on, the lights come on, ect. When I start to crank, nothing. not even a click. 10 to 20 minutes later everything is fine it starts right up. I checked the wires at the starter and at the battery. What's next? Could the solenoid be about to die?
It does this about once every few weeks. It's not heat related.
Old May 31, 2009 | 02:06 PM
baxsom's Avatar
baxsom
auto or stick
my th400 has a misadjusted safety switch
sometimes i get the same situation you are describing.
i tap the gear shifter and it starts right up.
i know i couldnt adjust it but its just a pita to fix something so trivial
Old May 31, 2009 | 02:14 PM
69Vett's Avatar
69Vett
Corvette of the Year Winner 2017
2016 C3 of Year Finalist
turn your headlamps on, try and start, if they stay on nice and brite no change,
you most likey have an interlock problem. or an open circuit,. good luck....69VETT
Old May 31, 2009 | 02:31 PM
Attfay Elleybay
It's an auto.
I bypassed the Neutral safety switch and it didn't help. I already thought of that.
Once I find the problem I'm hooking the NSS back up. I'm careful until then.
I also tried tapping on the solenoid but that didn't help either.
Old May 31, 2009 | 02:47 PM
...Roger...'s Avatar
...Roger...
Have you tried this ? This is a crude drawing of a temporary test light. It will tell you whats going on.
Old May 31, 2009 | 07:02 PM
69Vett's Avatar
69Vett
maybe a poor connection of the purple start wire,
going thru the Fuse-Box connection ?
this assumes you have throughly checked all your power and gnd. connection right ?
OEM style high milelage starters, use a large copper washer,
that can, arc over and become intermitant.
thats a possibility also ? 69VETT
69VETT
To still getting an intermittent 'no start'
