electric choke
Old May 31, 2009 | 12:48 PM
Attfay Elleybay's Avatar
Attfay Elleybay
Default electric choke
I hooked 12v up to the choke on my carb (Holley). The motor will turn over but refuses to start. It starts right up when i disconnect the 12v.
I tried loosening the 3 screws and turning the choke till the plate almost closes but that didn't help.
Could the choke be bad and need replacing?
Old May 31, 2009 | 01:16 PM
...Roger...'s Avatar
...Roger...
Whats the choke plate doing ? Is it open or closed ? When the engine is warm and you hook the 12 volts to the choke will the engine start ? Where did you pick up the 12v for the choke ?
Old May 31, 2009 | 01:24 PM
calwldlife's Avatar
calwldlife
St. Jude Donor '22
He has a good question.
The 12v to the choke only heats it to open.
Unplugging should close choke.
Are you stealing current from the ignition?
Old May 31, 2009 | 02:28 PM
Attfay Elleybay
I moved the 12v source to the yellow wire on the wipers. It might be ok now. It's 85 outside so I'll find out in the morning.
To electric choke
