Best Carb?
Currently I have a holley street avenger 770. I am having problems tuning the carb and I believe that it has too much cfm for my vette. It is running rich. I would like to sell this carb and try a different carb. Many Thanks
Don't change the carb - find the problem. Can you provide more information on the problems you're having tuning?
The Quadrajet, properly tuned, will give performance equal to any other carb, but will also give optimum fuel economy for street driving. None of the other carbs have the technology to do that, in spite of what anybody might say to the contrary.
God bless, Sensei
God bless, Sensei
If he cant tune the Holley, what chance does he have with a Quadrajet.
The Q-jet is a great carb and all, but it does have a bit of a learning curve to figure it out.
God bless, Sensei
God bless, Sensei
My 80 Vette with the motor in my signature gets close to the same cruising and it is a beast. Drivabillity on both cars is great. You just have to tune them! There is a lot you can do to tune both carbs. Just because most people don't spend the time tuning they should (or know how to) doesn't mean the carbs are bad!
ANY carb, properly sized and tuned will deliver very nearly the same results. The key then becomes....correctly sized and tuned.
This carb is not too big. As a comparison, the Q-jet typically flows around ~780 CFM.
The Q-Jet is a fine carb overall and a great street carb with the spread-bore configuration...but tuning one is an advanced skill IMHO, and the tuning parts are not as readily available as for other carbs.
The carb he's got is very adjustable and will work fine with some tuning...maybe we can wait for the OP to let us know the tuning steps they've taken to date and we can go from there
God bless, Sensei
......however the "new" carters that no one seems to talk about are a vastly superior model to the afb's they sold the rights to edelbrock to.....we order them regularly in the past and there is a great difference starting with annular discharge......
1. I have set both the idle mixture screws so that I get the most vaccuum pressure. It is around 13.5
2. I adjusted the float level so that gas is barely coming out the site hole.
3.I am using the silver spring in the secondary
If I change out the plugs, the vette runs very well without any miss. Once the plugs start getting rich(black) I will then notice the miss under load again.
The carb seem easy to adjust. What am i missing.
A primary jet change (and possibly a power valve change) is likely required and either a fuel-air meter (such as an Innovate) or some time with a pro tuner is suggested. The decision of how to proceed is based on how often you'll be tuning - either other cars or making significant changes to yours. If you're going to be doing this a bunch, investing in a good meter saves a ton of money over the long haul. You absolutely can do this yourself by just changing jet sizes until you're no longer coloring plugs - but it will ultimately take longer and may end up costing more. Holley produces a simple manual for making these changes and there are many other good resources on Holley tuning.
If it's a used carb, all bets are off. I've generally found that used carbs are typically way off, either becuase they were tuned for a specific engine very different than yours - or because they're selling it because they can't make it work....after changing everything. Start by restoring the carb to it's factory tune (jets, power valve, etc.) and work from there.
FWIW, I generally suggest adding $250-$300 to an overhaul budget for a tune. For a mild 350, many of the street carbs come with jetting that's pretty close - but step away from about 1 HP/CID or around 350 CID then the out-of-the-box setup isn't going to be right on...and a tune makes a HUGE difference in performance, driveability and fuel economy.
Without using a A/F meter, setting any type of carb is just an educated guess, about as accurate as setting the timing by ear.
Anyone that has ever used an a/f meter can attest to that and describe how far off a suppossedly tuned carb can be.
With that in mind, Holleys are extremely tuneable, and frankly quotes of poor mileage and poor performance come from the inexperienced, barely scratching the surface. In fact qjets are easier.
Seldom, have I seen Holley's set up properly to their fullest capability.
An investment in a A/F meter is a powerfull tool, no matter what type of carb you end up with, whether it be Qjets, Holleys, Demons, Webers, Dellortos, Mikunis or mechanical injection.
to drop around 8.5 vacuum before the power enrichment valve opens you want the engine to have to drop vaccum as low as 6.5 before the power valve opens, more then a good chance with the 8.5 under to light of load its opening up dumping fuel in when your engine is not under load no need for it. vast majority of street holley carbs come with a 6.5 power valve.
