Radiator electric fan sensor
Old Jun 2, 2009 | 10:30 AM
ladybridgeport's Avatar
ladybridgeport
Cruising
Default Radiator electric fan sensor
I have a 1974 Corvette and it has a hot rod engine in it, the electric fan in front of the radiator turns on with the ignition and stays on. Is there some sort of temperature sensor I can put on it so it shuts the fan off when not needed?
Old Jun 2, 2009 | 10:37 AM
Duke94's Avatar
Duke94
Yes, Flex-a-lite makes one that has a probe that pushes through the vanes of the rad. I have one on my 78' and it works great.
Gary
http://www.jegs.com/p/Flex-a-lite/Fl...51522/10002/-1
Old Jun 2, 2009 | 12:38 PM
Jeffski's Avatar
Jeffski
The fan I have on my car runs from a temp sensor that fits in the drain plug on the bottom of the rad. It has an adjustable setting to make the fan come on at any temp you want. Right now I have it set for 200 degrees. My whole setup was a street rod electric fan kit setup.
Old Jun 2, 2009 | 08:30 PM
ladybridgeport
Cruising
My mistake, it's a 1978 Corvette. I ordered the sensor. Duke94, what temperature is yours set to?
Old Jun 2, 2009 | 10:05 PM
Duke94's Avatar
Duke94
Mine is set to 180.
Gary
To Radiator electric fan sensor
