Help with a Holley
Old Jun 2, 2009 | 06:09 PM
buzzkill's Avatar
buzzkill
Default Help with a Holley
I tried to start my car and found that i got water in my tank. I drained the tank and filled with fresh fuel, then flushed the lines and tried to start the car. The carb wouldn't squirt any fuel, so I disassembled the carb, thoroughly cleaned it, and reassembled it. It still won't squirt fuel. So I pulled the sight plugs and the fuel level is exactly where it should be. What should I do next?
Old Jun 2, 2009 | 06:12 PM
midyearvette's Avatar
midyearvette
accellerator pump needle valve rusty???..just a guess..
Old Jun 2, 2009 | 06:19 PM
buzzkill's Avatar
buzzkill
Forgot to mention that it's a new carb. When I took it apart everything looked good except for a little white gel that I had to clean out of it.
Old Jun 2, 2009 | 06:32 PM
buzzkill's Avatar
buzzkill
Well against my better judgement I dumped a bunch more fuel down into the carb and tried one more time....fired right up.
To Help with a Holley
