Inline fuel pressure gauge question
Old Feb 7, 2002 | 09:59 PM
thebruce's Avatar
thebruce
Default Inline fuel pressure gauge question
In my quest to get my Edelbrock carb set up, I installed an inline fuel pressure gauge using a T fitting on the fuel line just before the carb. When I run the engine, the needle bounces back and forth very rapidly between zero and a higher number (anywhere from 5 to 10, depending on engine RPM). Is the gauge bad, is my fuel pump bad, or is this normal? Edelbrock recommends a fuel pressure at idle of 5.5, so I know I need a fuel pressure regulator, but I have to get a good reading on the fuel pressure to dial in the right setting on the regulator. Thanks in advance for any insight.
:flag
Old Feb 7, 2002 | 10:08 PM
73Ken73's Avatar
73Ken73
Default Re: Inline fuel pressure gauge question (thebruce)
When you put the regulator in the pulsation should stop. It seems odd that it pulses that much, you may have a bad pump or carb problems.
Smokehouse69's Avatar
Smokehouse69
Cruise-In VI Veteran
Cruise-In VII Veteran
Mechanical fuel pump is a diaphram pump that is driven by an eccentric on the camshaft, it is sort of like a bicycle pump in the sense that it does not put out a constant pressure. On each revolution of the camshaft the diaphram is flexed and the fuel pressure rises, when the lever relaxes the diaphram the pressure drops. So on a slow idle the the pressure will bounce noticeably. When the car is really cranking the rpms, the pulse will be less noticeable (because the time between strokes is shorter.)
Old Feb 7, 2002 | 10:10 PM
thebruce's Avatar
thebruce
73Ken73 and Smokehouse69- Thanks for the quick response. Off to the parts store I go....
:cheers:
To Inline fuel pressure gauge question
