Parking brake problem
Old Jun 4, 2009 | 01:57 PM
Brat's Avatar
Brat
Default Parking brake problem
I have replaced all the hard wear for the parking brakes in the rear hub, I have 6hr into this pain in the but job , here is my problem , when I put on the rotor and pull the hand brake on a few time i get a loud clicking noise from the hub when the wheel spins , I beleive its the lever that conects to the cable and goes into the hub to make the brakes come on , it seems to be moving and rubbing on the wheel hub , im at a loose on this any help would be great as I need to get this fixed for a saftey first thing in the morning .....Thanks guys
Old Jun 4, 2009 | 02:06 PM
tacosupreme's Avatar
tacosupreme
That sounds like it could be the lever to me. I accidentally installed one of levers upside down when I did mine a month ago, and it would hit on a part of the rotor and make a loud "clicking" noise as I rotated the wheel. With 6 hours of work in it already, you'll be able to take that one assembly apart and put it back together in less than 1 now I bet!
