transmission drain plug
Old Jun 5, 2009 | 03:28 PM
raulotero91's Avatar
raulotero91
Default transmission drain plug
Does a 1979 corvette small block have a transmission drain plug, or do i have to remove the whole pan? also, what could cause a car to accelerate sluggishly? The car revs fine when parked, and accelerates normally when the pedal is pressed slightly, but when the pedal goes more than halfway, it barely moves. It feels as if it is going to cut off. any help is appreciated. thanks
Old Jun 5, 2009 | 03:42 PM
71_S-Ray's Avatar
71_S-Ray
I have yet to see a stock drain plug for a TH350, TH400, or 700R4. You have to drop the pan and make a huge mess regardless of how careful you are. Each time I've changed my tranny fluid/filter, I buy a new pan with a drain plug so I never have to deal with that again... at least on the same car.
Regarding your acceleration issue, I'd say your timing is off. Probably running too rich. See BarryK's stickied Timing post (if you haven't already) and follow it to a T. It helped the reliability and performance of my vette a great deal.
Old Jun 5, 2009 | 09:11 PM
zmanc3's Avatar
zmanc3
No plug. So, since I was going to get wet with tranny fluid anyway, I took the pan off, put in the TCI fliter / extension and put on a TCI deep pan with plug.
zmanc3
Old Jun 5, 2009 | 09:54 PM
SH-60B's Avatar
SH-60B
X2
Old Jun 5, 2009 | 10:55 PM
barbs '69 resto's Avatar
barbs '69 resto
Account disabled by request 8 Feb 2010
The reason why auto trans don't come withs drain plugs is to require the pan to be dropped and have the filter replaced. I use a fluid pump that attachés to a drill and run one of the tubes down the dip stick tube and pump out about a gallon of fluid so I can remove the pan with no mess.
Old Jun 5, 2009 | 11:41 PM
SH-60B's Avatar
SH-60B
I never did get that reasoning. The lack of a drain plug just forces you to drain the fluid to get at the filter. You still don't have to replace the filter just because you lowered the pan, it's kind of a "while I'm there" thing.
A drain plug would make it all a little neater though.
Old Jun 6, 2009 | 07:44 PM
cargo247's Avatar
cargo247
Drain plugs are good
Todd
Old Jun 6, 2009 | 10:12 PM
noonie's Avatar
noonie
Todd
No need for a skid plate here.
Old Jun 7, 2009 | 07:09 PM
cargo247's Avatar
cargo247
if i bottom out that far i will have bigger problems than the drain plug
Old Jun 10, 2009 | 08:55 PM
raulotero91
wow thanks a lot for ur help guys. It turns out im going to have to drop the whole transmission pan because there is no plug
Old Jun 11, 2009 | 07:10 PM
1nicecorvette's Avatar
1nicecorvette
is that rtv for a gasket i see? so they say but im bout ready to go that route next time i change out the filter. any leaks?
To transmission drain plug
