ignition module heatsink compound should i replace it after 30 years?
Old Jun 5, 2009 | 07:59 PM
1nicecorvette's Avatar
1nicecorvette
Default ignition module heatsink compound should i replace it after 30 years?
another while im in there post--- ive read a couple posts here that the that the heatsink grease gets hard and crumbly and doesnt work as it should to transfer heat from the ignition module. is it a good idea to remove the module and regrease it with some new? i have plenty of heatsink compound from my computer shop i can use.
Old Jun 5, 2009 | 10:03 PM
SH-60B's Avatar
SH-60B
Sounds like a good PM practice to change it once every 30 years huh? I took mine apart just to clean it about 8 years ago when I re-built the motor. I put it back together dry and have had no issues. Not sayin' it's right, ... just sayin'.
Old Jun 6, 2009 | 08:28 AM
Jim Shea's Avatar
Jim Shea
If it lasted over 30 years some people might say to leave a good thing alone. However, it probably is a good thing to try and conduct as much heat from an electronic component as possible with new grease.
Jim
Old Jun 6, 2009 | 10:18 AM
tommyleea's Avatar
tommyleea
You better have another ignition module handy; that old module will probably crumble in your hands! Cheers
Old Jun 6, 2009 | 10:20 AM
69Vett's Avatar
69Vett
Corvette of the Year Winner 2017
2016 C3 of Year Finalist
get a new module and install with new thermal grease,
keep the old unit as a spare. 69VETT
Old Jun 6, 2009 | 10:42 AM
...Roger...'s Avatar
...Roger...
I think the problem will come from the 2 wires going into the pickup coil. They act as a hinge when the vacuum advance works and one of them is likely to break when you pull them off to apply the new grease.
Ganey's Avatar
Ganey
Exactly. That the way I do it, however 10 yrs. is a better max.
Old Jun 6, 2009 | 01:28 PM
1nicecorvette
okay i will replace it. i can get delco modules easily.now is there anything bout those two wires i should know about? like if they do break how would i repair them? im not inside the dizzy yet so i dont know where what is what yet. firgired it would be straight forward....suggestions?
Old Jun 6, 2009 | 01:43 PM
Ganey's Avatar
Ganey
The pickup coil wires break internally from being flexed by the vac. advance. From what I have seen it is near the pickup coil not the module.
The wires can be soldered or replaced.
To ignition module heatsink compound should i replace it after 30 years?
