o-ring for 77 auto trans
Old Jun 6, 2009 | 12:45 AM
onaqwst's Avatar
onaqwst
Default o-ring for 77 auto trans
i need to replace the o-ring for the speedo cable that ties into the trans. i dont have the original since i'm using a electronic sender and i think the current o-ring is the wrong one anyways. trying to avoid buying 20 o-rings to see what works...
77 auto trans..... i'm sure it's a stock trans also...so what ever it is..
b
Old Jun 6, 2009 | 08:35 AM
TimAT's Avatar
TimAT
Take your sender to the o-ring store. Find one that fills the groove and sticks up over the sender a little. Usually, if a ring fills the groove correctly, the diameter will be correct for the seal.
Old Jun 6, 2009 | 09:24 AM
bmotojoe's Avatar
bmotojoe
If you’re talking about the seal in the housing where the speedometer gear is thats not an “O” ring, it is a cup seal. Any local non chain auto parts store should be able to match it up.
Old Jun 6, 2009 | 03:30 PM
onaqwst's Avatar
onaqwst
thanks... i was going to pull out my sender unit for my electrical speedo and thought an o-ring was supposed to be in there. i have to buy a new speedo cable anyways so i might see if i can get a whole kit for the original setup
b
To o-ring for 77 auto trans
