Hi Guys, I've got a Holley 4175 spread bore with an electric choke on my stock 78 L-48. It starts good cold and also when the engine is hot up to about 20 mins after I shut it down. If it sits much more than 20 mins it starts really hard. Have to crank it alot and end up applying about half throttle to get it started, it also smokes pretty good once it is started. Is this a common holley electric choke issue or is there any adjustments I could make?
You can use a thicker gasket between carb and manifold and see if it cures the problem or not. Try at least 1/4" thick.
Try to put a hand on the fuel bowls when your engine is hot. If it's so hot you can't keep your hand on them, that's the cause of your problem.
Mr Gasket, Holley, Edelbrock and others make special ( called heat insulator or heat shield or heat dissipaters ) gaskets for this purpose, but you must first check if you have enough clearance between your air cleaner and the hood.
A carb spacer does the same thing, actually it is more effective, but it's even higher, at least 1/2" or 1"...
Sounds to me that after 20 min. the choke is closing again but the engine is still hot. A closed choke on a hot engine will flood it. Thats why you have to hold the throttle open to get it to start, and hence all the smoke.
Had the same issue. Checked the floats.....ok. Checked/adjusted the electic choke....no change. Put a heat insulated gasket under the carb......and.....presto!
But be careful. They are thick. If you do this, make sure you have hood clearance for your set up.
Google "Holley Electric Choke", you'll find a lot of information on how to adjust yours. I have one, and while it's not as good as an intake manifold heated divorced choke, it works well. I don't have exhaust cross-over heat, so an electric choke was the only solution, other than a manual choke which is a non-starter for me.
You can adjust the rate it comes on by turning the black housing to Rich or Lean, and you adjust the fast idle speed with the idle speed adjusting screw. With a lot of fiddling with it on a cold motor, you can get it right!
zmanc3
Mr Gasket heat dissipator kit is only 1/4" thick and works great in most cases. At least it worked for me.
It is made of 3 gaskets and 2 aluminium sheets
Recently, I made my own heat dissipator, and it works very well, even if it is only 1/4" thick too.
