timing question
Old Jun 8, 2009 | 02:16 PM
81cali's Avatar
81cali
Default timing question
will the timing on a stock motor be different from one that has a higher lift cam? should the latter be set more advanced or retarded?
Old Jun 8, 2009 | 03:04 PM
billla's Avatar
billla
St. Jude Donor '14
Total timing and the timing curve is different for every engine - but the only place to make those adjustments are on the dyno. I know that sounds like a BS answer - but the best power and driveability comes from a custom tune.
Engines with big cams may benefit from using manifold vacuum vs. ported vacuum for the vacuum advance as there's more vacuum advance at idle and it helps to smooth out a "bumpy" idle.
