Window Rattle Fix
Old Jun 8, 2009 | 09:27 PM
BillyTz06's Avatar
BillyTz06
Default Window Rattle Fix
On my recently purchased 79 T top the driver side window rattles really loud when you close the door and also when driving , like the window is ready to fall out, but only with the window down. The passenger side is not as bad. I removed the driver side door panel and found that the two gismos ( don't know the correct name) that should keep the window from rattling are in place and look in good condition but there is a lot of in and out play in the window. Does anyone know why this is occuring and what the fix may be.*
Old Jun 9, 2009 | 12:12 AM
Willcox Corvette's Avatar
0Willcox Corvette
Former Vendor
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
A few things come to mind:
The outer window felts that put pressure on the top of the glass in most positions. http://willcoxcorvette.com/product_i...ducts_id=26172
The door window pad adjusters hold tension on the glass and the pad wears out under the cat hair. http://willcoxcorvette.com/product_i...ducts_id=24196
The other thing is possibly a roller worn out on the regulator. http://willcoxcorvette.com/product_i...ducts_id=17008
Willcox Inc.
Old Jun 9, 2009 | 09:55 AM
08vycpe's Avatar
08vycpe
Thank you Willcox. I have exactly the same issue with my '79.
Old Jun 9, 2009 | 12:38 PM
1nicecorvette's Avatar
1nicecorvette
i had that issue too 79. tightned the bottom mounting bots (gently) on the window glass itself, then i adjusted the door pads out a bit so that hey were snug on the window. solved that problem.
Old Dec 18, 2019 | 03:31 PM
zrc3john's Avatar
zrc3john
Banned Scam/Spammer
Willcox Inc.
Ok fine..What am I ordering here ?
To Window Rattle Fix
