68 Brake Light Switch
Jun 9, 2009 | 01:43 PM
Seems this switch goes out about every 3 yrs or so and they are expensive.
Anybody ever replace the brake light switch with one from a 67 or 69?
If so what brackets and hardware do I need?
Jun 9, 2009 | 02:04 PM
You should be able to use or adapt any later year GM brake switch, about 8 bucks at any auto parts.
Jun 9, 2009 | 04:00 PM
Corvette of the Year Winner 2017
2016 C3 of Year Finalist
you have flushed the brake system right ?
only reason to go out is cheaply made, or Dirty brake fluid ?
Jun 9, 2009 | 05:48 PM
Is this the switch under the dash ?
Jun 9, 2009 | 08:46 PM
Mounts to the pedal assembly.
Completely different than 69up but there was a writeup on this forum quite awhile ago showing how to adapt the newer plunger type switch to the 68.
Jun 9, 2009 | 09:14 PM
opps, I thought the Brake pressure switch,
a thousand pardons !
Jun 9, 2009 | 09:28 PM
Quote:
Originally Posted by
69Vett
I was wondering what you were talking about it your 1st post Shannon.
Jun 10, 2009 | 08:52 AM
You can convert to 69-up stryle but you will need the striker bracket and the switch mount bracket. Unfortunately your 68 pedal assembly is not drilled to mount the 69-up switch bracket.
This is the 69-up setup:
The brackets:
Jun 10, 2009 | 09:58 AM
Jun 10, 2009 | 12:37 PM
I don't know exactly how it works, but from the looks of the switch you could replace it with a whisker type switch from an industrial electric supply.
See
http://www.grainger.com/Grainger/wwg...it+Switches%2C
Item 1MDZ1
You can find them for less money. Just a thought.
Jun 10, 2009 | 12:52 PM
Corvette Central part # 593034, 55.00. Seems to be a better cost option than NOS, depending on where it's made.
