Best Sparkplugs??? Is there Really a Difference?
With your mechanic. The AC's are an ok plug but the autolites are better. It should be burning clean with new plugs though.
on my L88 427 at 10:1 CR the 3 heat range works bad ( I tried AC R43xls and autolite 3923)
much better with 4 heat range: R44xls and autolite 3924.the autolite is best
I suppose that a proper wide gap is important too, but not as much as heat range
How wide of a gap you can use is all about the ignition system. IF you have a stout one that can jump the gap with high cylinder pressures at WOT...it will make more power. If not...it will lose power and bang and pop.
There ARE some plugs that do better under mega heat N20 conditions and stuff like that...but for regular stuff...just use the right heat range...likely hotter than you think is good for the street.
Also really hard to tell on exhaust color these days with unleaded gas and no cats.
JIM
JIM
Fast-forward to now with a 1974 350. The recommended plug is R-44T and that is what the car came with when I bought it in 2008. It was not running quite "right" and as the Q-Jet was past its "best before" date I replaced it with a rebuilt unit. Still a bit off despite tuning efforts. Based on the experience with the 1967 I tried R-45TS. Again, the cat's meow. So the A/C "5" heat range is for me and my type of driving.
As to gap, I use the recommended 0.035" for a points and condensor ignition system.
I am a novice and your mechanic is a pro but I am skeptical about tail-pipe tests (unless the engine is obviously suffering from a bad carb, blown head gasket, etc.). I would imagine that colour will differ from city driving (lots of idle) and a 70mph, 60-mile highway trip (off-idle). The defining factor for me is runnability and for the moment my 1974 humms from idle to speed. While I must confess that I have never tried Autolite plugs, I am loath to mess with the current setup. Many times in the past I have tried to take a 95% (+) situation to 98%, mostly with unpleasant consequences. So I'll stay with R-45TS.
I did not answer your question but I did wish to comment on the heat-range matter advanced by Jim.
In rare instances I have seen a brand change make a small difference on the dyno, but it's not that common. Autolite plugs were the only plugs that I found that would stand up to nitromethane, although in recent years Champion has come out with some Top Fuel plugs that work well.
http://www.se-r.net/engine/platinum_copper_ngk.html
EDIT: I do agree with the others that posted about running the correct heat range for your application. Your symptoms could be from too cold of plug. Your driving style and city, highway or racing could all affect the heat range needed.
All plugs start at the same temperature, normally the outside air temp. Its the function after warm up thats important. AC plugs of #45 is probably the best all around choice no matter what engine if its a street machine. Track use on a street car would be 44`s or 43`s. They operate cooler.
Champion is a better choice for racing because it`s easier to get a heat read on a Champion than a Black plug such as Autolite or AC`s.
All the rest of the plugs are just hype and price dont make any difference. Its like using premium or race gas for a low compression engine..A waste of money....However isn`t everyone loaded now since they got their stimulus money......
If only.
