on my demon 750 double pump there are the 2 small vacum ports on the right hand side .i have heard that one is a constant vacum and the other is only at certain times. if this is the case im guessing it is important which one goes to the kickdown and which one goes to the vacum advance on the dizzy. is this true or are they both constant and it doesnt matter.
The one on the outside is ported or timed vacuum, the inner one is direct manifold vacuum this is the one you should use for your vacuum advance on the dizzy.
