T Top Inside Skin?
Old Jun 12, 2009 | 07:17 PM
BIGJIM13's Avatar
BIGJIM13
Default T Top Inside Skin?
GUYS
Does anyone sell the inside piece of t tops - the piece that is glued to the outer shell piece?
Old Jun 12, 2009 | 07:28 PM
Mikes*Corvettes's Avatar
Mikes*Corvettes
Do you mean these?
http://www.zip-corvette.com/Corvette...758BB8D137F9E4
Old Jun 12, 2009 | 07:53 PM
BIGJIM13's Avatar
BIGJIM13
Hi
No I am talking about the inside part that has the latches and the pins the is glued/glassed to the outer shell. My pin ends are rotted out..
figured there would be someone that sells a replacement piece to reglass/glue on
Old Jun 12, 2009 | 08:01 PM
VETTEVIC's Avatar
VETTEVIC
Originally Posted by BIGJIM13
Hi
No there is no replacement piece available. You can take them apart carefully and make the repairs and glue them back together just like the rest of the car. I had to do this on mine, all the captured nuts and cages were rusted or gone and I had to make new ones and put them back together.
Old Jun 12, 2009 | 08:41 PM
chris75stingray's Avatar
chris75stingray
you might be better off buying a used good one
Old Jun 12, 2009 | 08:45 PM
BIGJIM13's Avatar
BIGJIM13
Yep figured I would go with the rebuild option...
fiberglass and resin
and cloth and panel adhesive...Man - I'm in Heaven!
Old Jun 13, 2009 | 08:45 AM
bluzman2004's Avatar
bluzman2004
Sorry to hi-jack, but how do you remove the inside covers? The ones in the link.
Old Jun 13, 2009 | 09:15 AM
BIGJIM13's Avatar
BIGJIM13
Mine are just pushed on with the heavy plastic velcro tabs
Old Jun 13, 2009 | 02:30 PM
VETTEVIC's Avatar
VETTEVIC
Hey Jim if you need help PM me. I have done this already and may be able to help.
Old Jun 15, 2009 | 04:23 PM
Dodosmike's Avatar
Dodosmike
Be careful when you give'em a pull. I did that with mine and the "plastic velcro tabs" pulled out of the paper like backing on the t-top liner.
I used old fashed white "elmers glue" to glue the little metal "velcro tab holder" back in place. Might be easier to remove if they are warmed up in the sun or with a heat gun. Not an easy thing to instal either. I had mine apart and together 3 times to get it fitting right. Installed the t-top on the car and installed the liner when I was sitting in the car. A little "pop" with the back of my fist seemed to hold it. You'll hear the "plastic velcro" click together when it "hammered home"
rubbersidedown
Dodosmike
Old Jun 15, 2009 | 07:46 PM
bluzman2004
Thanks for the info. I tried to replace them a while ago, but when I pulled on one it wasn't moving, so I didn't know if I was missing something.
To T Top Inside Skin?
