Need help with intake manifold selection
Old Jun 13, 2009 | 07:48 PM
MTC_75vette's Avatar
MTC_75vette
Default Need help with intake manifold selection
I currently am running an edelbrock performer eps manifold because to my understanding the rpm manifold will not fit under the stock hood. I was wondering if anyone knows of a easy way to modify it to fit under the stock hood or know of another manifold that will give me more power and higher rpm range than the performer eps.
Old Jun 13, 2009 | 08:00 PM
SteveG75's Avatar
SteveG75
Edelbrock does not know what they are talking about. Performer RPM fits fine. You just have to replace the stock aircleaner with a low profile one.
I am using the Performer RPM Q-Jet (same height as the RPM and RPM air Gap) with a Moroso Low Profile Racing Aircleaner and 3" filter. I have about 3/4" clearance at the front of the aircleaner with the stock hood. Only mod I had to make was a slight dimple in the base for the accelerator pump arm.
Old Jun 14, 2009 | 12:11 AM
Mick 72's Avatar
Mick 72
I have a 72 with stock hood and I'm running an edelbrock Original Torker manifold. Single plane low rise. rated at 2000-6000. Great intake!!! Have to get used cuz they oinly make the torker II now. Not as good.
Old Jun 14, 2009 | 08:17 AM
Ganey's Avatar
Ganey
Edelbrock's statement is true regarding the standard 68-72 small block hoods. The LT-1/BB hood is really the min. for the SB high rise intakes.
The 75-79 med. rise hood allows the Victor Jr, RPMs & others on SB w/ aftermarket dropbase filter & Holley.
Old Jun 14, 2009 | 03:49 PM
MTC_75vette
Thank you, for all your reply's. I guess I will order the rpm manifold and hopefully it fits with my low rise air cleaner.
To Need help with intake manifold selection
