1980 Interior lights and door locks
Jun 14, 2009 | 04:09 PM
Looking for some insight into possible issue with our 1980.
Checked door, hood and t-top switches and they seem to be opening and closing correctly but lights stay on constantly.
Also cannot get the power door locks to work. There is power to the switches and out of the switches but no power at the actuators.
Not sure if they are related.
Could this all be related to the anti theft system?
Any other insight or ideas would be appreciated.
Jun 14, 2009 | 07:00 PM
Look at you private messages area, I left you a message.
"DUB"
Jun 14, 2009 | 07:23 PM
Check to make sure that the light switches on the door are fully depressed when your door is shut. Also is the courtesy light function turned off at the headlight switch?
Jun 14, 2009 | 09:57 PM
Thanks for the help.
We were tracing the wires and found the interior light timer control relay of some sort to be hot as hell. Pulled it and the interior lights went out.
They work from the headlight switch as they should but just dont come on when the door is open.
Small victory for today.
Jun 14, 2009 | 11:28 PM
Quote:
Originally Posted by
bigjoepos
If you jumper the 2 whites at the timer control harness you will have the standard non-delay courtesy lights.
Jun 15, 2009 | 06:47 AM
Hey thanks for the tip.
Will try it tonight
Jun 15, 2009 | 09:31 AM
DWncchs
I have the same Problem, Could you please tell me where this relay is so I don't spend an hour looking for it. Thanks.
Jun 15, 2009 | 09:34 AM
chazcax
What year is your car ?
Jun 15, 2009 | 11:11 AM
DWncchs
My car is a 1982. I also need a fuse box diagram as I lost the one I had when my computer crashed.
Thanks.
Jun 15, 2009 | 11:33 AM
chazcax
Thanks.
The timer is to the right of the glove box behind the dash. Sorry I dont have a fuse box diagram on my computer. They have been posted before so I'm sure you can find one by doing a search.
Jun 16, 2009 | 05:36 AM
1980 ,
c3 ,
check ,
corvette ,
courtesy ,
door ,
function ,
fuse ,
interior ,
lamp ,
lights ,
location ,
locks ,
relay ,
switch
