Help on my 72 Power Windows
Old Feb 9, 2002 | 03:30 PM
Phlash's Avatar
Phlash
Default Help on my 72 Power Windows
Since I couldn't find a 72 like I wanted with power windows, I decided to put that option on the car. However, I would like to know where the power window relay is suppose to be. I know it should have a circuit breaker in the fuse panel that powers the relay, but I don't know where the relay should be mounted or what it looks like ( I suspect under the radio, or shifter but don't know for sure). Can anyone help? :confused:
Phlash 72 BB Roadster
Old Feb 9, 2002 | 03:50 PM
mrvette's Avatar
mrvette
Default Re: Help on my 72 Power Windows (Phlash)
I suppose GM wanted the relay to open the main circuit when key was off, keeping heavy currents out of the ignition circuit....makes sense...anyway...
I just wired my windows direct to the battery circuit, 30 amp cartridge fuse, and had over with it...simpler that way....
GENE
Old Feb 9, 2002 | 04:48 PM
454Big's Avatar
454Big
From factory it was mounted under the shifter console.
I don´t know how the thing looks like.
Perhaps you go your own wiring way or check with the AIM and a Haynes manual.
Old Feb 9, 2002 | 07:20 PM
7t2vette's Avatar
7t2vette
The ORIGINAL and bestest
Toronto Events Coordinator
On a 72, there is a circuit breaker under the hood at the driver's side beside the brake booster, and there is a relay under the console at the top driver's side.
To Help on my 72 Power Windows
