After 15 years it finally...
Old Jun 16, 2009 | 11:34 PM
MotorHead's Avatar
MotorHead
From: Who says "Nothing is impossible" ? I've been doing nothing for years.
Default After 15 years it finally...
....feels like a sports car now. 600+HP 427ci small block, TKO 5 speed overdrive tranny, new brakes and hydroboost, stiffer springs and Ultra High Performance Toyo TIR tires. Handles and accelerates like a killer machine now. I am happy..for now
Old Jun 16, 2009 | 11:59 PM
OzzyTom's Avatar
OzzyTom
Now get out there and enjoy it!
Old Jun 17, 2009 | 12:08 AM
shmoky's Avatar
shmoky
Yes very nice lookin'. Get out and enjoy it Any pics of the 600hp motor?
shmoky
Old Jun 17, 2009 | 08:14 AM
...Roger...'s Avatar
...Roger...
Looks good,now how about a video or at least an audio of you going through the gears on nice moderate run.
Old Jun 17, 2009 | 08:52 AM
gkull's Avatar
gkull
What you have is better, faster, and more refined than any of the yesteryear production so call Hot Rod 427 and 454 vettes
Old Jun 17, 2009 | 09:18 AM
Budman68's Avatar
Budman68
Cruise-In VII Veteran
St. Jude Donor '07
This post is worthless without video....strap your wife in that beast with a camera and let us experience the ride.
Old Jun 17, 2009 | 10:38 AM
MotorHead's Avatar
MotorHead
shmoky
I will get a camera inside and get some video, my brother offered to take a video along side in his car too
Here's the motor, specs below the pic, the motor should be putting out closer to 650HP / 600TQ, my previous 406ci was at 550HP and this motor is head and shoulders above it
Engine Specs are:
- World Motown 400ci small block, 350 mains with splayed billet caps,
- AFR 227 Eliminators with port matched Vic jr. intake by AFR
- T&D Shaft Rockers, 1.6 ratio, Manley .080" wall pusrods and
- Comp Cam small base circle Endurex solid roller lifters
- XR286R solid billet roller, small base circle lift .650" duration 248/254 @ .050"
- Callies DragonSlayer crank, 350 mains, 4 inch stroke
- Eagle stroker rods with ARP 2000 bolts
- Mahle pistons, with chromoly faced rings- 10.6:1cr
- ATI Race Super Dampner
- CVR billet timing cover
- CVR mini starter
- Cloyes timing set with encapsulated torrington bearing
- Melling HV oil pump
- Milodon 7 qt oil pan
- Edelbrock Victor water pump
- Hays lightweight ( 25lbs ) billet steel flywheel
- Center Force clutch
- MSD Digital E-Curve Pro Billet distributor
- MSD Super Conductor wires
- 825 Drag Race Demon carburetor
- Hooker Super Comp header into 3in. SS mandrel bend exhaust
Old Jun 17, 2009 | 10:51 AM
73StreetRace's Avatar
73StreetRace
Enjoy it !!!!
I bought my '73 twenty years ago, and it's still a "Work in progress"
Old Jun 17, 2009 | 11:06 AM
gkull's Avatar
gkull
What are your e-tec dist settings?
I use "J, 1" for 15 degrees all in at 3000 kind of slow advance courve and 1 for least amount of vacuum advance at the highest vacuum choice.
Old Jun 17, 2009 | 11:48 AM
Dustup7T2's Avatar
Dustup7T2
Terrorizing Orange Cones
Yes Sir. Yet another C3 risen like a Phoenix to raise havoc with rice burners, Porches, and hybrids who take up valuable real estate.
Smoke 'em if you got 'em.
Old Jun 17, 2009 | 12:11 PM
BKbroiler's Avatar
BKbroiler
That is a sweet ride for sure.
Old Jun 17, 2009 | 12:21 PM
Clint's C3's Avatar
Clint's C3
Nice job!! I'd be interested in the 1/4 mi times.
Old Jun 17, 2009 | 01:27 PM
shmoky's Avatar
shmoky
I love your valve covers "Built By Motorhead" Can't wait to see/hear the video
shmoky
Old Jun 17, 2009 | 07:02 PM
MotorHead's Avatar
MotorHead
Thanks guys, been driving it for 15 years and still can't wait to get in it, now that's money well spent
George the digital e curve I had was a POS, caused backfires under heavy load on my newly built motor. Could have ruined it. Could not figure out what it was, did not think it was a brand new dist. Took the cap off and found
1) Rusted contacts after 1 week
2) and it looks like the spark was travelling down the cap and grounding on the dist body under heavy load.
If you are having any problems with backfiring or anything similar send it back and tell them to put it in the same pile as mine
Old Jun 17, 2009 | 07:37 PM
C3 Stroker's Avatar
C3 Stroker
Got traction? Truly an excellent street machine! Now go run it!
Old Jun 18, 2009 | 09:19 AM
JohnRR's Avatar
JohnRR
Please tell us all about the suspension work you've done....
To After 15 years it finally...
