Recreated the vapor lock issue!
Old Jun 22, 2009 | 03:22 PM
ImBatman's Avatar
ImBatman
Default Recreated the vapor lock issue!
Well I was able to duplicate the problem. Took the Vette out Saturday and it ran awesome for 30minutes. Then I noticed it start stumbling under heavy throttle. Finally I could here the carb just sucking air when I tried to give it throttle. Started chugging and finally died. Front and rear bowls were empty. Let it sit for about 30-45 minutes and it fired right up and ran good again. Mechanical pump maintains a consistant 7psi before the trouble starts.
Looking more and more like it is a vapor lock issue. Running by the speed shop after work for some fittings to build a return line.
Wade
Old Jun 22, 2009 | 07:40 PM
Vette-4-Life's Avatar
Vette-4-Life
identical symptoms i had last summer. Had to replace fuel pump with one that had return line. The fuel pump GM recommended with the new crate engine had no return line. Have had no issues since replacing.
Old Jun 22, 2009 | 07:47 PM
Eddie 70's Avatar
Eddie 70
Ci 6, 8 & 10 Veteran
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15
Be sure to let us know when this works out for you Wade. Learning how to fix these things is part of the fun, if you want to call it that.
Old Jun 22, 2009 | 08:20 PM
mrvette's Avatar
mrvette
I have said many times how to solve the problem....stick a electric pump in back near the tank, and forget that return line crap, as totally not necessary....use a CARTER electric pump...
and if necessary, use a inline pressure regulator.....most likely for a Qjet.....
it works....
Old Jun 23, 2009 | 12:12 PM
ImBatman's Avatar
ImBatman
it works....
Gene,
Why would a electric FP solve my issue. I would think that the engine can only use so much fuel at a given time so you would still have fuel sitting in the line heating up even with an electric FP. Not disagreeing just asking.
Old Jun 23, 2009 | 12:36 PM
mrvette's Avatar
mrvette
Originally Posted by BlackRat
Gene,
it' snot at the crab to pump line that's the issue bubbles/boiling fuel will be shoved up just fine...it's on the SUCK side of the line from the fuel line to the pump that is at issue.....had a car LONG time ago, that was how I fixed it....rear mounted pump near the tank, and so ~4psi at the carb, whatever pressure it got in the line running forward.....not a issue after that...
that and on that heat riser crap, take that out/off the car, you maybe leave the passage under the carb open, but you don't need a valve to force hot gas under the carb, all that does is boil the fuel outta the thing.....
Years ago, almost all engines I had I filled the exhaust crossover/heatriser passage with plaster of paris, it's heat proof, let harden overnight, install in the morning....cured that crap of boiling/overheated carbs in a second......trick is, I didn't live in Minnesota for winters....so for Maryland that idea worked great....but gotta make sure that heat riser is OPEN or better yet removed....
Old Jun 23, 2009 | 12:43 PM
pauldana's Avatar
pauldana
I had this problem also.... drove me CRAZY
My fix was to dump the holly with its front/rear bowls and replace it with an Edelbrock with side bowls. fixed it permanatly 2 years now...
But just ordered a BG mighty demon last night and I am worried about the problem comming back.
Old Jun 23, 2009 | 12:59 PM
langlj00's Avatar
langlj00
Same problem a few years ago having upped the jet size after chatting to Lars - he suggested a small electric boost pump by the tank to help the poor old mechanical one out - worked a treat, no probs. since.
Jeremy.
Old Jun 23, 2009 | 01:52 PM
ImBatman's Avatar
ImBatman
Thanks Gene! My intake does not have the heat riser ports so I am good to go there. Electric FP does make sense. I hate to dump my mechanical Holley but if it fixes the issue then it will have to go. I did get the fittings already to hook up the return line. If this does not help then the electric pump is next.
Well I have been planing on switching to a dual Edelbrock AVS setup but was wanting to get some other things done first. Hmmm may come sooner than later.....
Jeremy.
Lar's is the one that actually told me I need the return line with the Demon. He was saying that it is a common issue he had run into before with Holleys and Demon's. He told me to setup the return as close o the carb as possible preferably coming off of the fuel log. I have a T fitting that I am sealing the back outlet with JB weld and then drilling a 1\8" hole in it to act as an orfice. Run the return line off of that.
Thanks for all the comments guys.
Old Jun 23, 2009 | 02:29 PM
PAmotorman's Avatar
PAmotorman
Wade
if you have headers and the fuel line is inside the frame in the engine compartment that could be your problem
Old Jun 23, 2009 | 03:42 PM
pauldana's Avatar
pauldana
I had the problem long before the change over to headers... for me it was that front bowl getting way to hot...
Old Jun 24, 2009 | 02:57 PM
502vett's Avatar
502vett
I have a holley blue electric mounted in the rear and originally had a dead head regulator near the carb and it would vapor lock all the time.
Since then I have wrapped my headers and replaced the dead-head reg with a bypass return style reg and ran a 3/8" return back to the tank and have not vapor locked since.
Old Jun 26, 2009 | 11:29 AM
ImBatman's Avatar
ImBatman
Well I have the log built for the carb with the return line coming off the back T . I still need to JB weld the barb and drill a 1\8" orfice. I also connected a 5\8 rubber fuel line to the return port on top of the tank but still need to tuck it into the frame rail. I also did not get enough fuel line. I thought 10 ft would do it!!! So I have to get a brass connector and join the line together.
Heading to the beach tomorrow for a week so no more progress for a few days.
To Recreated the vapor lock issue!
