Front brake stuck
Old Jun 22, 2009 | 05:51 PM
Attfay Elleybay's Avatar
Attfay Elleybay
Default Front brake stuck
About a mile from home, my vette started pulling to the left.
I babied it home and the drivers front rotor was smoking.
Autozone has the calipers in stock but doesn't have the pads.
They say two days for the pads. I'm going to see if 'Sebastian Auto' has them, but I doubt it. They're a smaller 'Mom & Pop' type store.
Do I need any special tools (star shaped or other) to change the rotors?
Or will a basic socket set do it?
Old Jun 22, 2009 | 05:53 PM
KapsSA's Avatar
KapsSA
Active Streak: 90 Days
Sounds more like a clogged/collapsed brake hose than a caliper problem.
Crack open the bleeder and see if things free up a little.
Old Jun 22, 2009 | 05:54 PM
Gordonm's Avatar
Gordonm
Check or replace the hoses also.
Old Jun 22, 2009 | 05:56 PM
GruntyPants's Avatar
GruntyPants
Agreed, a collapsed rubber hose will cause the lock-up, replace those first. And yes that can be done with basic hand tools. The tricky bit is to get the system bled properly again.
Old Jun 22, 2009 | 06:15 PM
dogboy's Avatar
dogboy
Also check the cap for the Master Cylinder. I had the rubber seal start to disintegrate and clog up the line right out of the MC causing the rear brakes to lock up. A New MC and a good flush fixed it.
Old Jun 22, 2009 | 06:17 PM
Attfay Elleybay
Would I be able to see if the hose is collapsed? It looks in good shape.
Old Jun 22, 2009 | 06:32 PM
Peterbuilt's Avatar
Peterbuilt
The hoses can collapse on the inside and the outside will still look ok. 20 years or more is way past there serviceable lifetime. PG.
Old Jun 22, 2009 | 06:49 PM
G dad's Avatar
G dad
From: THE OLDER I GET THE BETTER I WAS! NORTHERN ONTARIO
Weird...I had that same problem but with the right rear...calliper, is ok, but it was the flex hose that was no good.
Old Jun 22, 2009 | 07:07 PM
Attfay Elleybay
The caliper was leaking.
I checked the fluid in the Master Cylinder.
The front is nice and clean, the rear is cloudy.
To Front brake stuck
