Brake Question
Old Jun 23, 2009 | 01:36 PM
Attfay Elleybay's Avatar
Attfay Elleybay
Default Brake Question
Last post
http://forums.corvetteforum.com/c3-t...ake-stuck.html
Haynes Repair Manual said 2 bolts on the caliper, there were 5.
As soon as I loosened the caliper bolts, brake fluid started to pour out.
I'm changing the rubber hose also.
When I put the new hose on, do I need to attach it at the caliper first or on the hard line? Or does it matter.
Old Jun 23, 2009 | 01:40 PM
7t5's Avatar
7t5
St. Jude Donor '14
Originally Posted by Attfay Elleybay
Last post
You're doing it wrong. There are two big bolts that hold the caliper on Those are the ones to loosen. Doesn't matter what end of the hose is first, but I imagine it is easier to put it on the car first, let it hang, hook it up when you get the new caliper attached.
Old Jun 23, 2009 | 01:49 PM
Attfay Elleybay
When I removed the large bolts, that loosened the outside caliper. I had to remove 2 other bolts and a nut to remove the inner caliper.
The larger was 11/16s
the smaller were 5/8s
Old Jun 23, 2009 | 01:53 PM
7t5's Avatar
7t5
St. Jude Donor '14
Oops...sorry, been a while! Why did fluid come out?
Old Jun 23, 2009 | 02:36 PM
Attfay Elleybay
I think the caliper was leaking.
Old Jun 23, 2009 | 03:13 PM
KapsSA's Avatar
KapsSA
Active Streak: 90 Days
There's O rings between the caliper halves, when you loosened the 2 BIG bolts you broke the seal. Maybe that's your only leak if you didn't disturb the pistons.
Attach the rubber hose to the caliper first using the copper seal, then attach to the steel line.
To Brake Question
