side pipe installation?
Old Jun 25, 2009 | 12:34 AM
killer454's Avatar
killer454
Default side pipe installation?
I am putting side pipes on my 1980 the side pipes are made by hooker,says competition on them.
is their a way to cover up the frame and bottom of the front fender to make this installation look better?
thanks for the help
Old Jun 25, 2009 | 12:15 PM
71rdster's Avatar
71rdster
Put the rocker covers back on.
Old Jun 25, 2009 | 02:37 PM
MelWff's Avatar
MelWff
The pipes come with instructions that explain how to trim the rocker panels to fit the car.
Old Jun 25, 2009 | 02:50 PM
1Fordman's Avatar
1Fordman
You may or may not have to do some trimming on the front lower edge of the rockers where the pipes are.
On my 68 I took off the rear tires and slid the rockers into place with no trimming needed.
Old Jun 25, 2009 | 04:02 PM
L-82kid's Avatar
L-82kid
I removed the trim and installed the pipes and then put the trim back in place. Its a little tricky to get the trim in, you have to wiggle it and go in on an angle.
Old Jun 25, 2009 | 05:31 PM
aaroncorvette's Avatar
aaroncorvette
Also i found one of those telescopic magnetic thingys (used for retreving nuts and bolts in tight places) invaluable in drawing out the t-headed sidepipe bolts once the rubber was in place and for when you drop them into the rocker area, get a good quality one with a strong magnet
Old Jun 25, 2009 | 08:11 PM
killer454's Avatar
killer454
ok thanks for the help,I will have to buy a set of rocker covers to make this install look better.
thanks for the help
killer454
Old Jun 26, 2009 | 01:39 AM
Bangkok Dean's Avatar
Bangkok Dean
thanks for the help
killer454
I guess you are saying that your vette was missing the original rocker covers? If so you can order new ones from many of the vendors supporting this forum.
Old Jun 26, 2009 | 02:31 AM
killer454's Avatar
killer454
yes my car dosnt have any on it
check them out at willcox going to order them
thanks for the picture your car looks great,same color as mine
To side pipe installation?
