Wot
Old Jun 25, 2009 | 03:18 PM
benito's Avatar
benito
Default Wot
On my 69 350/350 4sp, should the throttle plate be straight up and down at WOT?
Old Jun 25, 2009 | 03:21 PM
Gordonm's Avatar
Gordonm
Yes.
The throttle plates, not the air valve on top of the throttle plates. You have to hold the air valve open to check the throttle plates.
Old Jun 25, 2009 | 03:27 PM
wombvette's Avatar
wombvette
This is going to develop into the `69 bent bracket syndrome.
benito's Avatar
benito
Thanks, I guess I have some work to do because I am not getting enough motion on the throttle cable to bring the throttle plates staight up.
Old Jun 25, 2009 | 03:28 PM
benito's Avatar
benito
What's that? The bracket at the carb that hold the cable?
Old Jun 25, 2009 | 07:47 PM
C3 Stroker's Avatar
C3 Stroker
......no, it's usually the one attached to the gas pedal; with use it always bends, taking away full throttle throw at WOT.
Old Jun 25, 2009 | 10:14 PM
benito's Avatar
benito
Thank you.
This looks like another "under the dash working upside down in an area you can't see" job!
Old Jun 26, 2009 | 12:57 PM
73StreetRace's Avatar
73StreetRace
If I remember, only two bolts have to be removed to get the gas pedal out of the car.
The throttle cable can be removed easily from the pedal so you can work on it at the workbench and eventually bend it a little more if you need
This often happens with thicker carpets too...
Old Jun 26, 2009 | 01:37 PM
...Roger...'s Avatar
...Roger...
If your not feeling like pulling it out here is a pic of a way to shorten the cable a little bit which will open the carb more. Just pull the cable a little attach a zip tie and trim it off and release. A bit bubba but you can always remove it when you feel like doing it right.
Old Jun 26, 2009 | 03:40 PM
timgman's Avatar
timgman
No, Bubba would have crimped a beer cap from a PBR long neck on there with some vise-grips....
Old Jun 26, 2009 | 09:31 PM
1nicecorvette's Avatar
1nicecorvette
thats how we got rid of the dead spot in the 2001-up mustangs was that way. because the cable would pull before actually doing anything the fix was the put a spacer of some sort inline such as a zip tie.
Old Jun 26, 2009 | 10:50 PM
benito's Avatar
benito
The Bubba method works for me! At least for now.
To Wot
