Help decode this 4speed
Old Jun 25, 2009 | 10:13 PM
steve228's Avatar
steve228
Default Help decode this 4speed
I read a previous post on this,and copied the codes down on paper,but I cannot decipher it.Can anyone help?
It is a 75 4 speed.
28 spline front shaft.or near that.
On the right side case is upside down the date
1/8/1975
then right side up is :
1304 065 903
W.G.Div.
F G
P 1
On the Top csae stamped is 27
On the left side(the lever side) is:
WD 1052
Anyone know the specs,assuming it is stock.?
Thank you in advance.Steven.
Old Jun 26, 2009 | 07:54 AM
BB72's Avatar
BB72
That would be a ST-10 Borg Warner transmission. Good strong transmission.
April 10th, 1975, 2nd production shift.
903 means aluminum case.
http://fiedlerh.home.att.net/BW.htm
Old Jun 26, 2009 | 08:30 AM
pbcanney's Avatar
pbcanney
what a wonderful link. Thanks!
Old Jun 26, 2009 | 09:08 AM
steve228's Avatar
steve228
Thank you BB72. That is a good source,thank's for the link.Steve
Old Feb 28, 2012 | 11:29 PM
racer93saljr's Avatar
racer93saljr
2nd Gear
Default need some help
I have a trans I need help with. 1304065903 fine spline 6 grooves on input shaft 3-18-81 mlt-11d1 any info would be apreciated thanks .
Old Feb 28, 2012 | 11:33 PM
racer93saljr
2nd Gear
Default trans help
I also have a trans # 3884685, g103021 11 spline input 27 output,3885010 side cover # . p7p19, 3088336 any info thanks
To Help decode this 4speed
