pre-'85 and '86-later engine blocks....What's the difference?
Old Jun 26, 2009 | 03:17 PM
Ak. Mal's Avatar
Ak. Mal
From: Kansas City, MO ...I'd like to go fishing and catch a fishstick. That'd be convenient. - Mitch Hedberg
Default pre-'85 and '86-later engine blocks....What's the difference?
What makes the Gen 1 blocks different between the pre-'85 and the '86-later blocks?
The question is brought up because I'm planning on having my engine rebuilt. I like the idea of a roller cam, so I'm doing some research here on the forum. Do the -'85 engines have to be machined to make a roller cam worked? If so, what machine work has to be done?
Old Jun 26, 2009 | 03:46 PM
L88Plus's Avatar
L88Plus
Pre 86 engines used flat tappet cams, 2-piece rear main seal. Some of the later blocks are equipped for hydraulic roller cams, all of 'em have 1-piece rear main seals, dipsticks are all on the passenger side of the block. The earlier blocks generally don't need any machining to run a roller cam but will need a cam button and retrofit roller lifters.
Old Jun 26, 2009 | 06:08 PM
7t5's Avatar
7t5
St. Jude Donor '14
I thought you had to machine in some screw holes in the valley of the pre 86 motors so you can install keepers to keep the lifters indexed properly. Roller lifters cannot be allowed to spin in the bores. Am I correct? is that what you meant by retrofit a roller cam? I think that is pretty involved.
Old Jun 26, 2009 | 06:28 PM
ratflinger's Avatar
ratflinger
NCM Grand Opening Veteran
St. Jude Donor '11, '17
You either make bolt holes for the OEM style dogbone keepers and spiders or you have to use link-bar lifters. Link-bars are more expensive & there have been some issues with the bars, but I believe that is in the past. Pre-roller blocks must use the cam buttons, roller blocks come with a bolt on cam keeper.
Old Jun 26, 2009 | 09:47 PM
markdtn's Avatar
markdtn
There are 2-bolt and 4-bolt versions like the earlier ones. There are conversion kits to use a 2-piece-seal crank in a late block, but why? The bearings are the same, mounting holes in the block the same, really no external difference except the flexplate/flywheel. One small thing to note, many "late" blocks have the pad cast for a fuel pump, but the hole for the pushrod to the cam lobe is not drilled out.
Old Jun 27, 2009 | 01:26 AM
Ak. Mal's Avatar
Ak. Mal
Thanks for the great info guys. Anymore trivia or bits of knowledge about them, please let me know.
If I were having a machine shop rebuild a long block from a '86+ engine, could they easily adapt a mechanical fuel pump?
Old Jun 27, 2009 | 07:42 AM
L88Plus's Avatar
L88Plus
If you want to run a mechanical fuel pump, you need to find a block with the provisions for one. If the pushrod hole is not drilled out, any competent machine shop can handle that. If it doesn't have the fuel pump boss at all, it can't be added. All the late TBI (early 90's) I have do have the boss and it's drilled, so look for those.
Old Jun 27, 2009 | 09:57 AM
'75's Avatar
'75
So, do all '86 and later blocks have provision for the roller cam, such as the bolt holes for the spider in the lifter valley. I understand that not all of those blocks had roller cams, but I'm not clear if its as easy as geting the roller cam and OEM hardware or some will need to be modified.
To pre-'85 and '86-later engine blocks....What's the difference?
