steering control valve!!!!
Old Jun 26, 2009 | 10:38 PM
80_vette's Avatar
80_vette
Default steering control valve!!!!
3 years ago I replaced my ps pump , hoses , cylinder and valve...And the control valve was bought new,not rebuilt.ever since I installed it I have always had a small leak from the valve...there was a small drop of fluid at the seal where the two halves connect together with tow bolts,and the fluid was like a grayish color and no one seemed to know why.....I never had to add any fluid,that's how slow the leak was....
Tonight I was about to go for a drive and found a leak on the garage floor underneath the control valve.Seems to be leaking more now.I tried to tighten the two bolts and I tightened them pretty hard but still seems to leak..but less!!
Should I attempt to rebuild it?It is the least expensive way and we are planning to go to the big carshow( the Nationals) in 2 weeks and don't want to miss it.
I appreciate the info..
Old Jun 26, 2009 | 10:46 PM
Richard Cooper's Avatar
Richard Cooper
I replaced my control valve with a rebuilt one from Auto Zone about 4 years ago and it has been fine. I think I only paid around $100.00 for it and its warranteed for life.
Old Jun 26, 2009 | 11:03 PM
80_vette's Avatar
80_vette
I was a bit weary about buying a rebuilt so I bought a new oneand this is what I have to deal with
Old Jun 27, 2009 | 07:49 AM
Duke94's Avatar
Duke94
I believe all the "new" ones are made in China and the quality of machining is not as good as OE. In my opinion, you are better off buying a rebuilt original.
Gary
Old Jun 27, 2009 | 09:51 AM
80_vette's Avatar
80_vette
Gary
ok..That's the first I hear of that,so maybe if I rebuild this one I will probably end up with the same situation?
Old Jun 29, 2009 | 09:33 PM
80_vette's Avatar
80_vette
ok...I attempted to remove my control valve tonight but it's quite a pain to remove from the pitman arm...should I have both wheels off from the ground? I actually have only the drivers side off the ground...Would that make it bind some how???
TIA
Old Jun 30, 2009 | 09:26 PM
80_vette's Avatar
80_vette
Got 'er....only way was with an air gun....
To steering control valve!!!!
