lowering my '81
Old Jul 3, 2009 | 12:06 AM
RIJVETTES's Avatar
RIJVETTES
Originally Posted by bedlam
awesome. thanks. i understand. i remembered how the leaf went in, but didnt quite realize the tension thing with longer/shorter bolts.
thanks for the input!
i wont be doing the cutting myself, as ive never done it before and want it done right. i found a corvette shop in dallas, and emaild them on a quote for having them cut.
i need to upgrade the front shocks though right? or are the OE ones good enough. cause they are new. if so, anyone try the KYB GR-2s? i had them on my accord before i went with adjustable dampers, and was kinda on the fence with em. and the bilsteins are expensive. lol.
-roy
I like my KYB GR2's. I've had them on my 80with the 330 lb rear composite spring, oem suspension and stock 15 inch wheels for 6 years. No complaints, with spirited driving. But I think you'll find that a lot of guys on this forum are dedicated to the Bilsteins.
Old Jul 3, 2009 | 06:01 PM
redman76's Avatar
redman76
St. Jude Donor '09
I just put 550# spring on my front and it dropped it about 1". I've never heard of the 550s raising the car. Everything I read is they lower. I guess it depends on the spring configuration. I think you can buy longer bolts for the rear for about $20 from most suppliers. Call Dan or Russ at VanSteel, they can help you get what you need.
Old Aug 5, 2009 | 08:19 PM
bedlam's Avatar
bedlam
so 550lb spring is the same as the 550#?
Old Aug 5, 2009 | 11:06 PM
Rebelrob's Avatar
Rebelrob
Yes, check out Vette Brakes & Products. They are a sponsor and are very knowledgeable when it comes to brakes and suspension for these cars. If you got deep pockets, they can set ya up. Not meaning they are expensive, but they have so much to choose from. I have the 550lbs coil springs on my car. They dropped it about an inch or maybe a little more. Ive got maybe 1.25 inches from the top of the tire to the fender lip. I have some longer bolts for the rear but have not installed them yet. I took my measurements before I took the rear apart. I am hoping for at least a 1.5 inch drop in the back.
Old Aug 6, 2009 | 03:20 AM
Leung's Avatar
Leung
Good lookin' CG5. I have one too as well as an 81' coincidentally.
Old Aug 6, 2009 | 07:28 AM
FB007's Avatar
FB007
Originally Posted by bluegtp
so, installing longer bolts relieves the spring of tension which in turn lowers the car. the shorter bolts put more tension on the spring by straightening it out and raises the car.
I hope this makes sense, it's 1 a.m. so someone correct me if i'm wrong!
Okay. Your wrong.
Old Aug 6, 2009 | 07:54 AM
RobbSalzmann's Avatar
RobbSalzmann
St. Jude Donor '12
bluetgp: The use of longer bolts lowers the resting point of the spring ( and connected body ) relative to the axle, thus lowering the car. This relationship has no material bearing on the tension applied to the spring.
Bedlam: Some people use the # to mean lbs (pounds). Those are some nice looking cars!
Old Aug 7, 2009 | 01:39 AM
bedlam's Avatar
bedlam
sweet. i love it. great car. have you upgraded yours at all?
oooooh yeeeeah. i didnt even relate those two. haha.thanks for connecting the dots for me. i promise im not THAT stupid.:o
