79 vac. advance ???
Old Feb 11, 2002 | 02:53 AM
kenincanada's Avatar
kenincanada
Default 79 vac. advance ???
should the advance be on or off at idle. I tring to lower my idle speed , but I dont want it to bog when I take off
Old Feb 11, 2002 | 03:05 AM
utahrookie's Avatar
utahrookie
Default Re: 79 vac. advance ??? (kenincanada)
I'm not positive but the only time I disconnect my vacum advance is to set my timing. So I would guess "no" for setting my idle speed. But I've been wrong many times before. :D
Old Feb 11, 2002 | 12:07 PM
john's '81 mouse's Avatar
john's '81 mouse
Disconnect vacuum advance when you set the timing, but have it connected when you set engine idle speed, cause it'll be connected when you are driving/idling your vette.
To 79 vac. advance ???
