major blow by
Old Jun 29, 2009 | 03:30 PM
pauldana's Avatar
pauldana
Originally Posted by midyearvette
we do it all the time for guys that built their own engines and screwed up the ring job.....no need to pull the mill to re ring....you may consider all new rings .....why not? youre already there...good luck
How long does it take?
I am figuring 1 day to rip it apart, 2 days to put it back togetere and another 2 becouse sh@t happens...
and... anything I shpould be looking for?/////
Old Jul 15, 2009 | 07:37 PM
pauldana's Avatar
pauldana
ok... got the engine out and I have it in pieces on the bench.
Hopefully some one can help me with this.... after taking the engine out I did a leak-down test again... all cylinders read 90+.. very good, no great look of blow-by bast the first ring....
Can rings seat and unseat? O, rings were very sharp, cut myself 3 times, so they are not washed you from running to rich....
This major blow by came after about 1 minute run at 6200 RPM.
also a ruff running engine, as if a cracked ring... but no...
all the symptoms of a cracked ring, blow-by & ruff running... but that is not it.... also heads look great!
any ideas?
Old Jul 15, 2009 | 09:48 PM
MotorHead's Avatar
MotorHead
From: Who says "Nothing is impossible" ? I've been doing nothing for years.
Sorry to hear of your misfortune. Where do you run a motor at 6200RPM for one minute ?
Old Jul 15, 2009 | 11:03 PM
pauldana's Avatar
pauldana
we have a few very long empty roads... through in a C5.... and.....anyway, what else would make blow by besides pistons and rings?
Old Jul 15, 2009 | 11:20 PM
427Hotrod's Avatar
427Hotrod
2020 C2 of the Year - Modified Winner
2020 Corvette of the Year (performance mods)
C2 of Year Winner (performance mods) 2019
2017 C2 of Year Finalist
You need to take it to machine shop and have them bolt a TQ plate on it and run the hone through it a few times to get cylinders dead round. Hopefully just a little bit will do it.
Sharp rings? What kind were they? What oil have you been using?
JIM
Old Jul 15, 2009 | 11:32 PM
pauldana's Avatar
pauldana
JIM
I'm doing the work, its in a full machine shop, the owner and I are friends. He is stumped also, Got a new set of rings ordered, ch/al,
..... oil, rotilla for first 500, then mobil-1 to 2000, then RP to now... 5000...and yes, i will run it through the hone,,,, but what else?....
Old Jul 15, 2009 | 11:58 PM
MotorHead's Avatar
MotorHead
If you are running 6000+RPM for anything more than a few seconds between shifts then you need top notch parts everywhere on the motor.
I don't mean Eagle crank and rods either. You need the best stuff, that is full racing territory and you can't fool around.
I have allot of money tied up in my 427ci and I would take it to 7000RPM between gears no problem but for a sustained period of time above 6000RPM I would be looking at spending another 10 grand or so on parts.
I am not saying you are not running good parts just trying to help here.
As for your problem, my money is on the parts just couldn't take the RPM
Old Jul 16, 2009 | 12:08 AM
pauldana's Avatar
pauldana
As for your problem, my money is on the parts just couldn't take the RPM [/QUOTE]
OK..... What part?
O, its a forged crank..........
Old Jul 16, 2009 | 01:46 AM
OMF's Avatar
OMF
What kind of rings where in there?
1. Cast
2. Ductile moly
3. Chrome
Have you had a very close look at the piston and the bore in the suspect hole? Something must have a telltale sign.
Old Jul 16, 2009 | 03:59 PM
pauldana's Avatar
pauldana
1. Cast
2. Ductile moly
3. Chrome
Yea, I agree...but I cant find any so far... Chrome moly....
