Rear trailing arm removal
Old Jun 28, 2009 | 12:04 AM
71_S-Ray's Avatar
71_S-Ray
Default Rear trailing arm removal
Having issues with the front bolt on the rear trailing arm. I've WD40'd the heck out of it, beat the outside end with a hammer and no budge. I'm considering the option of using a sawzall (which I don't currently own which is why I have gone straight to this) and wanted to know exactly where are you cutting with the sawzall? From all the posts I've read, it appears people are cutting on each side of the trailing arm but inside the bracket on the frame. The way I'm looking at this area, that is where the shims are located.
Do the shims become a casualty of war? How do I know what shims go back in there if I cut the crap out of my shims?
TIA... Brent
Old Jun 28, 2009 | 12:18 AM
temvette72's Avatar
temvette72
If you start the cut carefully, you can still tell how many shims are needed on each side. If the the bolts are that rusty, the shims will be rusty too. So, you'll probably want to replace them anyway. They are relatively cheap, in the big scheme of things. I used a really long blade, and as the blade wore, I cut the end off, thus moving to fresh teeth on the blade. I still went through a bunch of blades.
After all of that cutting, I got the t-arms out, but (get this!) the little stubs of the bolts were still frozen in the holes in the frame. I had to pound the heck out of them to get them to finally pop out!
Temvette72
Old Jun 28, 2009 | 12:38 AM
71_S-Ray's Avatar
71_S-Ray
Originally Posted by 1Fordman
Two things to try before the sawzall.
Put a 5/8 box wrench on the bolt head on the inboard side and see if you can work the bolt back and forth to break it loose.
Option 2 is an air impact gun with a mushroom head bit.
If you must use a sawzall make note of the shim pack on each side of the ta.
What year are you working with and do you have a long cotter pin running through the shim pack pocket? If so you proabably have the slotted shims which are a lot easier to get out than the 68 - 70 ones.
If not go back with slotted stainless steel shims and drill the pockets for a 3/16" long cotter pin.
I have a '71 and not sure what you're talking about with respect to shim pack pockets, cotter pin, slotted shims, etc. The removal/design of these T/As baffle me. Thank you for the two non-sawzall ideas. I will try them right now.
Old Jun 28, 2009 | 12:44 AM
71_S-Ray's Avatar
71_S-Ray
Correction.... I now know about the Cotter Pin. It was buried underneath a bunch of crud. I'm going to try and take that out so I can remove the shims. Maybe the bolt will come out easier without the shims.
Old Jun 28, 2009 | 09:34 AM
...Roger...'s Avatar
...Roger...
Once the shims are out removing the bolt or cutting it off is easy. Removing the shims is the toughest part.
Old Jun 28, 2009 | 01:10 PM
Snowman's Avatar
Snowman
CI 1-2-3-4-5-6-7-8-9-10 Vet
St. Jude Donor '03-'04-'05-'06-'07-'08-'09
You will have plenty of room once the shims are out. Will need to realign the rear end anyway so if everything else is rusty, just toss it all out.
If you haven't found the cotter pin yet (or for others reading along), look in picture below with new offset TA installed but unshimmed. You will see a black "dot" which is where the cotter pin goes.
Here's what it's supposed to look like when it is all done!
Good luck in your adventure!!
Doug
Old Jun 28, 2009 | 02:18 PM
71_S-Ray's Avatar
71_S-Ray
Doug
Hey Doug. Nice size tires in the back of you car. What size are those? Any other modifications required outside of the offset trailing arms?
Edit: Nevermind, I forgot who I was talking to. Love you build!
Old Jun 30, 2009 | 10:13 PM
71_S-Ray's Avatar
71_S-Ray
It took some battered up hands and a few hours, but I finally got the shims out. There's a couple metal hard lines that appear to be in the way of the bolt, so not sure how I'm going to get the bolt out and even if I do, I have no idea if I'll be able to get a new bolt back in. Geesh, what a horrible design...
Old Jul 1, 2009 | 09:51 AM
08vycpe's Avatar
08vycpe
If you are going to cut the bolts off remember that a high quality blade designed for metal will be required. Those are hardened bolts so get a good blade.
Before you cut have you tried CRC freeze off? I have had incredible luck with removing bolts that I swore would never come off. The spray is extremely cold when it hits the bolt. That along with a wrap to shock the bolt/nut and fasteners that would not come off with any other spray just comes right off. No need to spray and wait overnight either.
Also, have you tried heat? It's the same principle but in the opposite temp direction. Heating the fastener with a hand held map gas torch works well also. Just be careful with the flame.
Best of luck.
Old Jul 1, 2009 | 10:00 AM
Gordonm's Avatar
Gordonm
Best of luck.
Correct on this. A 14 or 18 tooth blade will do the job. Make sure you get a good bimetal blade, I prefer a Lenox blade because I work for Lenox. Don't cheap out here, there is plenty of garbage out there. 1 will do it fine but most buy two. I have cut many a hardened bolt out with these. You can find them in HD or Lowes. A little cutting fluid will help also.
I use a set of long needle nose pliers to reinstall these bolts.
Old Jul 1, 2009 | 01:15 PM
Dustup7T2's Avatar
Dustup7T2
Terrorizing Orange Cones
Sawzall: you're my hero.
Old Jul 1, 2009 | 01:28 PM
...Roger...
Nice work....now just take an angle cut on what remains of that strut rod,split it and peel it off,remove the rubber,drive a chisel in the opening in the inner sleeve,put some WD in the opening and that shock mount will come right on out.
Old Jul 1, 2009 | 03:38 PM
smon's Avatar
smon
You can also use a 2/3 jaw puller that you can rent from autozone to remove the shock mount...just dont go hammering on it. I used the puller, but cutting stuff is always fun.
Sean
Old Jul 1, 2009 | 03:59 PM
wcsinx's Avatar
wcsinx
To reinstall the new ones, drill a small diameter hole out on the tip. Tie some 50# monofilament fishing in the hole in the tip, feed the line through from the outside through the trailing arm and pull the bolt back through.
There's already a hole in them for the cotter pin.
Old Jul 1, 2009 | 10:25 PM
wcsinx's Avatar
wcsinx
If you use the cotter pin hole with the monafilament through it the ta bushing tube hole is not big enough for it to pass through easily. Thats why a 1/8" hole was drilled out on the rounded tip on the end of the bolt for the line to pass through.
Ehh? I used some nylon twine in the pin hole, and the bolt slid right through.
Old Jul 2, 2009 | 11:21 AM
2armor's Avatar
2armor
SHHHEEZ, How did you keep the saw that clean??? Wrap it in plastic?
Old Jul 6, 2009 | 11:48 PM
71_S-Ray's Avatar
71_S-Ray
Default Sawzall does it ALL!
I can be one stupid stubborn SOB sometimes...
Although there were some encouraging posts on how to remove the front trailing arm bolt, I should've listened to the large majority and bought a sawzall in the first place. I tried literally for hours trying to get that bolt out which included spending a ton of time looking for ideas outside of buying a sawzall here on the forums, battering up my knuckles, throwing tools, and even consuming lots of beer to no success at all.
So today, I finally decided to buy a sawzall. Best freaking $120.00 I've ever spent!!!! I cut the bolt on both side of the T/A in 16 MINUTES!!! Someone please bop me on the head and next time tell me not to be so darn stubborn!!!
Thanks again to all who provided assistance. It's because of you that I would have even considered buying the sawzall and the funny thing is... I actually am not dreading the left side now.
To Rear trailing arm removal
