horn problems need help
steering column problem-the lower shaft moves in and out real easy now for some reason,i can grab the lower shaft that attaches to the gear box and move it with very little resistance at all.did i breake somthing in it or is it ok to put back on the car?
horn problem-bought new plastic rivits and upper horn contact kit(rod,spring,plastic keeper)
when i put this together if i tighten the 3 screws that hold these parts in ,the horn button will not go in and out to operate the horn.
how is this assembly spose to move in and out with the horn button when the 3 screws are tight to the hub?
i really need some help with these problems any help would be appriciated very much.
thanks guys
In order to check the system, remove the relay and connect a volt meter or test light to the black (-) and red (+) wires through the connector. If you have voltage when the button is pushed the horn mechanism is working properly. Next you need to check the relay. You can re install the relay and see if there is voltage on the green wire when the button is pushed. I took my relay apart and found it was rusted beyond repair (about $12.00 or so) and installed a new one. Problem solved. You may want to bench test it since it is such a tight fit under the dash. Look to see which connector corresponds to each wire. Connect 12 volts to the red wire terminal, ground the black wire terminal and use your meter/test light to ensure 12 volts on the green wire terminal. You should hear the relay click as the coil magnet is energized. If all this is working properly, you will need to test each horn by putting 12 volts directly into the horn itself. The problem is most likely the relay, unless you have have been working on the steering column. If there is a problem between the relay and the horn units there will be a grounding issue on the horn units or a broken green wire supplying the horns. This should allow you to at least narrow your search to a specific part failure.
Hope this helps, If you need more clarification let me know.
jay
If you then snap the horn button back on and it won't depress when you press on it you may not have the shims installed or not enough shims.
GM has a .010" gap in the AIM for button travel when you push on it and the shims are what sets this dimension. My car has 3 shims and a spacer.
Check your AIM to be sure you have all the parts and they are installed in the right order.
Best of luck.
08vycpe you just figured it out for me after reading your post went out to the garage and checked but no spacer or shims at all.
i allready checked willcox and i see now what i have to buy,i wish i would have noticed those parts not being their the first time i ordered the rest of those parts.
thanks for the help
