edelbrock performer #2701
Old Jul 2, 2009 | 08:53 PM
vette7747's Avatar
vette7747
Cruising
Default edelbrock performer #2701
Stock 77 L48...If keeping Q-jet, stock Air-cleaner and stock Hood any PROBLEMS w/this Intake? Besides looks, any Real advantage here? THANKS All.
Old Jul 2, 2009 | 09:04 PM
stingraymyway's Avatar
stingraymyway
From: Out of Site...Out of Mind. Corvette: anything else is just transportation.
St. Jude Donor '09 thru '20
Got one on my '75. Think it's a 2116. No problems untill the Q-Jet crapped out, see other threads.
It's got do give you a few extra HP and weight savings.
Clearence for the hood/air cleaner were fine. Just lower the hood gently the first time.
Old Jul 2, 2009 | 09:23 PM
robashard75uk's Avatar
robashard75uk
I may be completely wrong, but don't the quadrajet carbs need a spreadbore manifold, and not square like the performer. My old quadrajet removed from my 75 L48 engine is spreadbore and I put a performer manifold on mine with a Holley 600, which is square bore.
Rob.
Old Jul 2, 2009 | 10:13 PM
SteveG75's Avatar
SteveG75
Rob.
2701 is a squarebore manifold. Adapter will be required to run a Q-Jet. That will make clearance an issue.
2101 (non-EGR) and 3701 (EGR) are direct fir Performer spreadbore manifolds. I had a 2101 with a stock aircleaner with no issues.
Old Jul 2, 2009 | 11:02 PM
RIJVETTES's Avatar
RIJVETTES
You will probably not feel any performance gain by just swapping the intake manifold, but the Edelbrock aluminum intake will be lighter and look better. I got the 3701 for my 80 vette (California emissions) and there are no hood clearance problems. Its height is almost identical to stock.
Old Jul 2, 2009 | 11:11 PM
vette7747's Avatar
vette7747
Cruising
You guys are GREAT!!! Saved me from making a 150.00 mistake on buying the Wrong intake. Thanks MUCH...Any other Info. Appreciated, Dave
Old Jul 3, 2009 | 07:22 AM
RunningMan373's Avatar
RunningMan373
2101 fit fine on my '73, even with a 1/4" gasket, but just, it is higher then stock. C.
Old Jul 3, 2009 | 08:48 AM
Ganey's Avatar
Ganey
2101 works w/ Q-J. Previous 2101 is best for performance.
http://forums.corvetteforum.com/c3-t...er-intake.html
To edelbrock performer #2701
