'82 Hood Latch
Problem is, I have no idea what I'm looking for under there. I'm trying to find a picture of the latch for an '82.
Can someone with an '82 or a year that would be similar take a picture of their passenger side hood latch (with the hood open) and post it here?
Also, I read that sometimes you can reach the cable from the middle of the hood. I'd like to try doing this as well, if someone has a picture of what I should be pulling on under there.
I'm trying to be as delicate with this car as possible.
Thank you!
You're sinply tripping the same lever that the cable pulls down.
It helps to raise the wipers and park them up.
My only guess is I was on the hood spring.
I'll go out and try again, this time making sure it is horizontal.
I had to open my hood that way for a month until I had the chance to fix it. You probably have a broken cable mount. They are plastic and break easy. I replaced mine with rubber coated metal cable stay/mount, works great!
First, I'm going to answer my own question for people who may need to know this in the future.
In this picture the cable has already been disconnected, but you can see the grommet you have to push INTO the inside of the engine bay.
You can also see the lever you need to trip with your SHORT screw driver.
(1982 Corvette Hood Latch)
Hopefully rats have not been in your car.
Now my question:
Is this cable routed properly or did someone install the wrong length of a cable? I figured it should run in a straight line along the top of the hood seal and not be routed around various engine components.
Also, what is the best source for a new cable? I don't want any cheap reproduction crap that doesn't fit.
