trailing arm bearing replacement
Old Jul 4, 2009 | 09:49 PM
corvettevet's Avatar
corvettevet
1st Gear
Default trailing arm bearing replacement
I have a 74 corvette, I need to replace the rear wheel bearings and have heard that this can be a little tricky. Is there a GOOD repair manual or procedure on how to do this? I have access to bearing pullers, presses and induction bearing heaters. Can you help me or put me in contact with some one who has changed these little beggers out successfully?
Old Jul 4, 2009 | 09:55 PM
jhuff's Avatar
jhuff
get in contact with gtr1999 he is very knowledgeable about this subject, and is a very good machinist.
Old Jul 4, 2009 | 11:13 PM
Carl Granquist's Avatar
Carl Granquist
Default SEARCH feature
Use "search" for this. It'll be worth your while. There's a tremendous amount of information on this forum. Many knowledgeable folks have contributed and there's good documentation. As for trailing arms, Gary has posted great photos of his work.
To trailing arm bearing replacement
