More carb issues (I think)
Old Jul 6, 2009 | 11:12 PM
Quil's Avatar
Quil
Default More carb issues (I think)
Finally got the car back out after getting my power steering hooked back up and had a fantastic cruise, all the way back until when I got back to my neighborhood. The car was idling perfectly one second, and then the next its's barely idling, sputtering when I try to accelerate, and trying to stall out on me. In fact, it did finally stall out right in front of my driveway, but I was able to get it started by flooring the gas pedal as I turned it over. Limped it into the garage...
Seems like maybe it's flooding, but I'm not sure... I've also had similar symptoms from a bad fuel pump before. Anyone have any thoughts on where I should begin?
Old Jul 7, 2009 | 05:46 PM
Quil's Avatar
Quil
Bump...needle and seat got some trash in it maybe? Anyone have any suggestions?
Old Jul 7, 2009 | 09:32 PM
namvet6869's Avatar
namvet6869
what year is it???????? i have a 81 with the electronic quadrajet. i had same problem and fought it for 6 months. ended up installing new ecm and m/c solenoid.
Old Jul 7, 2009 | 10:10 PM
a1sensei's Avatar
a1sensei
Year? Carb?
Old Jul 7, 2009 | 10:15 PM
Quil's Avatar
Quil
Sorry guys, I thought I had put that information in the original post. It's a '75, no ECM, with a Holley 650DP, mechanical secondaries.
Old Jul 8, 2009 | 09:12 AM
capevettes's Avatar
capevettes
CF Community Team
Active Streak: 90 Days
2016 C2 of Year
2015 C3 of Year Finalist
Pull the primary and secondary needle valves and blow them out. Put them back in and re-set your float bowl levels. You probably have some debris in there. Happens to me at least once a year.
Old Jul 8, 2009 | 01:47 PM
Quil's Avatar
Quil
Yeah, I'm thinking the same thing...either trash in the needle/seat, or the float stuck. I'll pull it apart tonight.
To More carb issues (I think)
